Old 7th June 2004, 12:06 PM   (permalink)
Default Count-down timer
Can someone get the circuit for a count-down timer. if possible, an explanation along with it.
thanks
sword is offline
Old 7th June 2004, 05:45 PM   (permalink)
Ok, basically, this is for a GCSE project.
i need to make a count-down timer to be built in with a steady hand toy
thing is, i have no idea where to start and i need things like tutorials with diagrams and stuff like that to help explain to me how to make this timer.
can anyone help
sword is offline
Old 7th June 2004, 07:07 PM   (permalink)
Are you looking to use logic chips or a microcontroller??
Kent
kentken is offline
Old 8th June 2004, 01:31 PM   (permalink)
The only economical option i can think of is a custom programed microcontroller. anything else would be like a custom chip or something.
I'll get straight to the point: if you haven't had experience with microcontrollers, your at a dead end.
www.winpicprog.co.uk - Great PIC language tutorials.
pike is offline
Old 9th June 2004, 07:10 AM   (permalink)
If micro-controllers are "at a dead end", my only choice then is logic gates. can you give me a starter on how to do this?
thanks
sword is offline
Old 9th June 2004, 07:26 AM   (permalink)
What is this to mean :?: :?: :?: :?: :?:
This can be easy with a Pic and a few 7-segs or Lcd.
With the help of this Forum. :wink:
Good luck
Kent
kentken is offline
Old 12th June 2004, 10:21 AM   (permalink)
I did one some time ago.
See http://www.electro-tech-online.com/v...=7350&start=15
It may be more complicated than what you need, but if you read through all of the posts, I expect you will obtain some benefit.
Using a PIC for a simple counter is like using a sledge hammer to crack a nut.
If you need more help, just ask.
Len
ljcox is offline
Old 12th June 2004, 11:28 AM   (permalink)
I would disagree, unless it's using a very tiny, very cheap, and very simple sledgehammer - as opposed to a larger, more expensive, more complicated, method of doing it.
The huge advantage of PIC's (and similar micro-controllers) is that they are cheap enough, and small enough, to use as replacements for many other chips. In this case the counter could be one single chip, giving far more versatility and capability than your relatively complicated multi-chip design.
Often the use of a PIC is massive overkill (personally I would quite happily use one to replace a 555, because of the vastly improved performance), but by making the project cheaper, simpler, and better, I see no problem with overkill.
However, the use of PIC's doesn't really apply to this thread, the question is for a GCSE project (UK exams you take at 16) - presumably it requires a hardware solution?.
Old 13th June 2004, 08:49 AM   (permalink)
I thought you may disagree Nigel.
But if everything is done using PICs, hardware design skills will be lost.
Besides, I expect there are PIC projects that need some hardware around the PIC to perform functions that the PIC can't do, or is too slow, etc.
Len
ljcox is offline
Old 13th June 2004, 02:25 PM   (permalink)
We're in the 21st century now, many 19th century skills have been lost, and not being missed - I see no point in using antiquated techniques when a modern technique is far better than old primative ways.
However, as I mentioned before, as an educational exercise it's perfectly valid - it's just not cost effective as a practical project.
Yes, there are obviously many, and it's important that designers have the skills to do so - but it's rather like arguing that the project shouldn't use TTL/CMOS chips - it's losing the design skills of building the entire project from discrete components (and what happened to all the valve computer design skills?). Which strikes me as exactly the same argument that you are putting forward!.
Old 17th June 2004, 02:22 AM   (permalink)
Default Hi!
Hey!
If u want to make it with CMOS, you should try the 4029, and a 4511 for the 7seg display.
E
Durchfall is offline
Old 18th June 2004, 03:03 PM   (permalink)
go to http://www.allaboutcircuits.com/vol_4/chpt_11/3.html. it explains the up, down and the up/down counter.
samcheetah is offline
