Old 6th July 2009, 11:05 AM   #16
okey .... i understood .
As your project is for a limited temperature range, say +2C thru +50C, it would make sense to amplify the LM35 output so that a tempr of +50C would give a voltage Vin to the adc of +2.5V,,, which would give the max resolution from the adc of 255. i think u talked about this , but please would u clearify it again i mean how will amilfy it to give you 50 c for 2.5 v
The range between 2 to 60 degcent .... ok
i want to ask about the accuarcy of the a LM35 , from the datasheet it is a +0.5/-0.5 , knowing this value , in what that will help me ?
thank you
alkoko111 is offline
Old 6th July 2009, 12:05 PM   #17
thank you
So your Tmax is 60Cdeg, the LM35 will output +0.6V for 60C.
If you set the LM358 to a gain of 4.17, this will increase the 0.6V to 2.5V.
So for Tmax the adc [with a Vref=2.5] will have an Vinp of 2.5V which will convert to 255 decimal.
In your PC program you will have to multiply the 255 by say,2.353 to make it equal to 600, which be equivalent to 60.0Cdeg
As an option, as you are amplifying the LM35 output to the ADC, you could just use the +V[5v] ref of the ADC.
This would mean amplifying the LM35 0.6V by 8.33, so the 0.6V would become 5V, which with a +5Vref would give 255.
This method for the Vref is simpler and cheaper.!
If you think about it, if you made the Tmax = 51Cdeg, so the LM35's 0.51V was multiplied by 9.8 to +5V, this would give an adc value of 255.
When multiplied by 2 in the PC program would give 51Cdeg.!
The +/-0.5C accuracy is over the temperature working range of the LM35.
OK.?
ericgibbs is offline
Old 6th July 2009, 12:16 PM   #18
ok ..... allright .
???? i did not get it
thank you very much eric .
Old 6th July 2009, 12:44 PM   #19
ok ..... allright .
Look at this graph from the LM35 data.
Examine the Tempr plot over the full range of the LM35.
Old 6th July 2009, 04:56 PM   #20
thank you so much eric .
for any new doubts I'll DISCUSS it with you .
Old 13th July 2009, 12:00 AM   #21
hello .. eric ! i want to ask about something
About the temperature . someone implement the project like me with these values :
Vref=1.28 v . applied on pin9 is 0.64 v
LM358 works as buffer .
he used these formulas :
To get the minimum span that the adc can identify . min-span=Vref/255
To get the Vin . Vin= Dout * min-span
then :
=1.28/255 = 5.01 mV
He that this the min-span according the formula. and we know that the adc will give us 10 mV / centi but here will give us 5mv/centi ..... which mean we will take the output of the adc and divide it by 2 to get the tempr .
example : if the output is 00000010= 2 in decimal then the program will read 2 and divide it by 2 to get the tempr ...... 2/2=1 c .
is that make any sense ? i asked him about why you divided by 2 ? but he did not respond till now ?
what do u think ?
note : the program is working fine as this person illustrated .
Old 13th July 2009, 08:21 AM   #22
Why is pin9 at 0.64v, it should be 1.28v in order to give a Span of LM35 [1.28v] = 255 adc value.
Repeating myself, in this application a buffer is NOT required, it serves no purpose.
This should be equivalent to 1.28v/255 , when the Vref is 1.28v
This should read: adc value out = [Vin /1.28v] * 255
then :
=1.28/255 = 5.01 mV
So for 5mV CHANGE in Vin ,,,, adc val = [0.005/1.28] = 1 count CHANGE
BUT a 5mV change is only equal to 0.5Cdeg change in temperature at the LM35, so a 1Cdeg change would give an adc value of 2.
He said that this the min-span according the formula. and we know that the adc will give us 10 mV / centi but here will give us 5mv/centi ..... which mean we will take the output of the adc and divide it by 2 to get the tempr .
So if you want to convert this adc value of 2[decimal] to 1Cdeg, you need to divide by 2.
Yes.
Look at my explanation above.
what do u think ?
I would still advise to use the LM358 as an amplifier for the LM35 output also use the ADC's internal 5Vref.
Old 13th July 2009, 08:57 PM   #23
okay .... i think this is convinced . thank you so much ...any new doubt i 'll DISCUSS it with you .
home, miniproject, monitoring, weather
Guys this is my home made 2.1 Home Theater System pasanlaksiri Electronic Projects Design/Ideas/Reviews 40 11th November 2009 05:07 AM
Weather Station jigzpad General Electronics Chat 8 27th December 2008 09:54 AM
Weather Vane otm Electronic Projects Design/Ideas/Reviews 64 24th November 2008 06:37 PM
DIY Weather Stations leongibbs Electronic Projects Design/Ideas/Reviews 3 8th February 2005 03:25 AM
Weather station ala199 Electronic Projects Design/Ideas/Reviews 7 17th March 2004 02:46 AM
