Old 6th June 2004, 10:05 PM   (permalink)
Default help me to understand this
hi friend
this criciut is for sine wave genrator using the IC called NC-1458 which have 8 pin's but criciut seing 4 is he using one IC ?.... after design from where we know it,s genrating sine ware
plz help friend,s
imgemini is offline
Old 6th June 2004, 10:42 PM   (permalink)
The MC1458 is a dual op-amp. Pin assignments are as follows:
Pin 1 - Output A
Pin 2 - Inverting Input A
Pin 3 - Non-inverting Input A
Pin 4 - V(ee)
Pin 5 - Non-inverting Input B
Pin 6 - Inverting Input B
Pin 7 - Output B
Pin 8 - V(cc)
ChrisP is offline
Old 6th June 2004, 10:44 PM   (permalink)
BTW -- Motorola MC1458 Datasheet
ChrisP is offline
Old 6th June 2004, 11:31 PM   (permalink)
The chip has two op-amps so he is using only one chip thats how schematics are drawn. So yes only one chip is used.
magickaldan is offline
Old 7th June 2004, 09:23 PM   (permalink)
Default thx,s but
hi friend
can u plz help me to understand from where i can get output sine wave . any way i can know in which frequency it is working on
plz help friend,s
imgemini is offline
Old 7th June 2004, 11:18 PM   (permalink)
You will get a square wave from pin 1 and a sawtooth from pin 7.
The frequency will be roughly between 100 and 1kHz. No sine wave.
kurtjo is offline
Old 8th June 2004, 06:01 PM   (permalink)
Default thxs
thx,s friends u just slove my problem i guess :lol:
plz help friend,s
imgemini is offline
Old 25th August 2004, 03:17 PM   (permalink)
Default hi
what is meaning by 10 a 12 a here in cricuit plz
plz help friend,s
imgemini is offline
Old 25th August 2004, 06:24 PM   (permalink)
Default Re: hi
Well, obviously they are the same node and it is very poor practice to give the same node more than one name, so I might assume that really there is a physical connection point there like a connector or some other means or physical connect-disconnect. If this is the case, it is also poorly drawn because they are not drawn properly..
Optikon is offline
Old 28th August 2004, 12:03 PM   (permalink)
Default hi
hi
this ad-resistor the GND and the out both are connected together .
plz help friend,s
imgemini is offline
Old 28th August 2004, 01:06 PM   (permalink)
Default Re: hi
hi
It's simply wired as an adjustable resistor, giving just two connections. When they are wired using three connections (like a volume control) it's called a potentiometer.
Old 29th August 2004, 01:20 PM   (permalink)
Default hi
plesae tell me what is the name of this part
is this Varactor diod or swtch diod ...or what .and plesae see the circuit above bcoz making any statement :arrow:
plz help friend,s
imgemini is offline
Old 29th August 2004, 01:24 PM   (permalink)
as picture shows
10a & 12a closed ... 10c & 14c opened ----> square wave
10a & 12a closed ... 10c & 14c closed ----> sawtooth
plz help friend,s
imgemini is offline
Old 29th August 2004, 01:25 PM   (permalink)
and from where i get the output for square wave and sq wave
plz help friend,s
imgemini is offline
