Old 24th June 2009, 09:03 PM   #16
Hi again,
Yes i agree that the 3055 isnt that great of a transistor, but it's well documented
so it makes a handy device to learn from.
MrAl is offline
Old 24th June 2009, 10:18 PM   #17
Originally Posted by Mr RB View Post
Umm just a question, do you really need to use a 3055?
They are designed to be driven from another transistor ie they are very low gain. The 3055 was just a cheap *final stage* transistor with reasonably high current and high dissipation.
A very astute question -- I'm going to go with "no." The 3055 is probably overkill, sort of like swatting a fly with an h-bomb, in my case.
These days there's almost certainly a better BJT for a single component motor driver. What's your motor current range and voltage?
I'll let you know as soon as I find out. I basically pulled an unmarked motor so I'm not really sure about that particular motor. I may try to get some measurements (or I may just get another motor for which I can get a data sheet).
I suspect it is somewhere in the 300-800mA range for runtime with stall current around 1-2A judging by a Mabuchi motor of similar size / voltage range / rpm.
The motor doesn't need anywhere near the max capacity of a 3055. It was just a convenient power BJT that radio shack had in a pinch which was less likely to overheat than TO-92 packaged transistor.
So anyway, to find a better BJT, I'll start a new thread.
Michael Shimniok
http://bot-thoughts.blogspot.com/
Microcontrollers can solve world hunger, too!
shimniok is offline
bjt, saturation, transistor
8051 Up Counter Verification Needed Frosty_47 General Electronics Chat 0 21st April 2009 04:31 AM
Solenoid switch circuit verification richacm Electronic Projects Design/Ideas/Reviews 21 15th June 2008 09:58 PM
Transformer Saturation dknguyen General Electronics Chat 16 29th December 2007 09:39 PM
Saturation questions. littletransistor General Electronics Chat 22 31st August 2006 04:52 PM
Commom-Collector saturation patroclus General Electronics Chat 8 3rd February 2006 09:27 AM
