Old 24th June 2009, 06:54 PM   #16
i'll do myself
That's a good idea. Don't expect our efforts if you can't put in enough effort to explain your project fully.
You don't need a quadraphonic Blaupunkt -- you need a curve
ball.
BrownOut is offline
Old 24th June 2009, 07:11 PM   #17
Default Digital lock
The project is to fashion a metallic box-like safe that will be locked with a 4 digit combination digital lock based on LS7220. The key pad should have 12 buttons. (Actually, i'm coupling the circuit, i'm not the inventor). If the right combination of keys are pressed, the lock opens and remains open for some seconds and then locks again. My major constrains are that i can't see the LS7220 and an electronic lock for it in Nigeria. Diagram http://www.circuitstoday.com/wp-cont...ck-ls-7220.JPG
Valentine is offline
Old 24th June 2009, 07:16 PM   #18
If you can't get the LS7220 that's a problem. You could try a microcontroller based design but you'd have to learn to program and you may have problems getting that too. Not many businesses will ship to Nigeria.
Bill
Smart Kits build Smart People
Old 24th June 2009, 07:27 PM   #19
And what about the Lock, if you don't mind
Old 24th June 2009, 07:36 PM   #20
Originally Posted by Valentine View Post
If the right combination of keys are pressed, the lock opens and remains open for some seconds and then locks again. [/url]
What happens if you dont shut the door before the lock re-engages?
It would necessitate having to re-enter the code....
Not the best of ideas I'm afraid....
The lock mechanism could be a simple solenoid...Can you get one of them in Nigeria?
Eccentric millionaire financed by 'er indoors
Chippie is offline
Old 24th June 2009, 07:39 PM   #21
Look at these:
ELECTRONIC BOLT LOCK ELECTRIC LOCKS ELECTRIC DEADBOLT ACCESS CONTROL Electromechanical Bolt Locks Electronic Deadbolt
Or else just search for "electric lock"
ball.
BrownOut is offline
Old 24th June 2009, 07:42 PM   #22
The chip isn't really made for this application. Your senario would reqire additional logic to keep the lock from engaging while the door was open.
ball.
BrownOut is offline
Old 24th June 2009, 07:46 PM   #23
The lock should be i such any way that it can close even if the circuit power output is gone. Just like you can lock some doors without the key but opens it with only the key.
Old 24th June 2009, 07:50 PM   #24
Then you need something like these strike plates.
» Electric Strikes & Magnetic Locks
Won't be as secure as an electric dead bolt, however.
ball.
BrownOut is offline
Old 24th June 2009, 08:02 PM   #25
Can't you buy safes in Nigeria? Why does it have to be electronic?
Bill
Old 28th August 2009, 07:36 AM   #26
do u have a cicuit for sentral , also how can i write its sotware
murtada is offline
digital, lock
Need full schematic "Miniature digital pin number lock" using PIC16f877A chunei Micro Controllers 9 29th October 2009 02:53 AM
Need Help on a digital lock project using PIC16F877A redadonis Micro Controllers 8 25th October 2009 11:11 AM
Digital code lock using 12F629 shankarsha Micro Controllers 15 8th March 2009 11:14 AM
How to make a DIgital Lock? daiict Electronic Projects Design/Ideas/Reviews 2 30th October 2003 07:52 AM
Digital Combi Lock Lizo Electronic Projects Design/Ideas/Reviews 3 24th September 2003 12:03 AM
