I'm embarrassed to say that I've had this very elementary problem for weeks now, without finding the solution by my self.
I have a micrcontroller device producing a 1kHz PWM signal that I would like to use to switch a power circuit on and off*. This is primarily being used as an LED-dimmer device. The 1kHZ PWM apparently precludes the use of a mechanical relay. All I want is something that can be switched on/off at 1kHz. Energy efficiency is important also as it will be running on AA NiMHs.
* Currently the microcontroller is 5V, but soon will be moving to 3v device. The power circuit consists of one or more (in parallel) 1W LEDs each running at 0.35A and ~3.6v (3xNiMH AA). A max current of 1A would be fine.
Is the answer obvious? Any specific devices spring to mind? As always, your help is greatly appreciated.
Here's what I've being toying with...
MOSFET:
More complicated operation than I expected, since efficacy depends on gate-source and drain-source voltages. In my case these are very/too small (both <5v) for the random sample of power MOSFETs I've looked at.
Power transistor:
Simpler to understand, but consumes current at base and incurs C-E voltage drop, unlike MOSFET. I can live with these, but I want this device to be as energy efficient as possible.
Solid-state relay:
A mystery to me. Some of these seem to be beefed up optocouplers.
