Hi. I'm an electronics newbie. This is my first big project that is not a kit. I have studied some basic electronics theory but I dont know what components I should use for regulating the power with this project.
My design so far uses ATMega8 microcontroller and a HM55B compass module. It will be powered by AA cells. The microcontroller needs to be able to control eight small coin pager vibrators (Though probably only one or two at a time). The problem is that the microcontroller needs 5 volts and the motors need 1.5 volts. The microcontroller's outputs can supply up to 40mA at 5V, but the motors need 70mA.
So I figure I need some kind of active components here (e.g. transistors) to regulate the power for the microcontroller and a transistor for each motor with resistors to split the voltage. I have done some research and looked through the catalogues of some electronics suppliers and I am simply overwhelmed by the amount of components to choose from, I have no idea what to use.
Could someone suggest a good setup setup for power regulation? Also any tutorials on this issue would be great.
I'll try to upload some schematics tommorow, right now they are all on paper.
Thanks!
