Old 14th June 2009, 06:59 AM   #1
Default Sealed Lead Acid Battery Discharge Protection
I want to build battery backup for my Master Clock so it keeps running when mains fails.
My Master Clock page is here.
Electronic Master Clock
I have the basic charging and backup circit (see diagram) using a 6v sealed lead acid battery.
The circuit works fine but my only concern is that a long power cut will discharge my battery too far and shorten it's life.
Is there a circuit for discharge protection so I can preset a voltage where my battery is taken out of circuit?
I notice solar panel regulators have this function built in but they all work with 12v batteries.
Thanks.
Brett.
oliverb is offline
Old 14th June 2009, 07:20 AM   #2
Here is something I posted for just a visual LED indication that a 12V SLA has discharged too low. You can use this basic circuit by tailoring the voltage divider on the Ref input to the TL431, and modifying the output side to switch off your load. Can you do that, or do you want some help?
MikeMl is offline
Old 14th June 2009, 07:39 AM   #3
Here, I modified it for you: Scale the time axis to match the discharge time of your battery. What do you want to use as the final cutoff voltage? If I didn't guess it, you can play with the resistive divider. I'm taking a wag that the 2n3906 will drive your clock. If not, you could use a bigger PNP or a PFET.
MikeMl is offline
Old 14th June 2009, 08:53 AM   #4
Thanks MikeMl.
I did measure the current from the PSU of my clock and I think it was 300mA ( I should have written it down). There is also another 250 to 350mA to drive the electro mechanical chime on the hour. This is max 12 x 350mA pulses on the hour into an electromagnet.
The 30 second electromechanical slaves are powered from a seperate supply so I will sort the supply for this later.
In your circuit if the battery was disconnected when it dropped below a set voltage would it try to switch back on when the battery voltage raised again due to no load?
If so I could use the OP transistor to switch off a relay instead of the battery. I could then configure the relay to hold itself off via it's own contacts. Therefore once the voltage threshold had been reached the relay releases shuting down the power to my clock and holding itself off.
A reset button would have to be pressed to reset the relay.
oliverb is offline
Old 14th June 2009, 09:38 AM   #5
Found an article on the TL431 Information On Electronics Articles and News: TL431 Battery Voltage Monitor
oliverb is offline
Old 14th June 2009, 09:48 AM   #6
Originally Posted by oliverb View Post
hi Oliver,
Not cutting across what Mikes doing, but is the battery in question on any sort of float charge.?
ericgibbs is offline
Old 14th June 2009, 09:55 AM   #7
Hi Eric
The battery is floated at 6.75 volts.
Brett.
oliverb is offline
Old 14th June 2009, 12:11 PM   #8
Hi Eric
Brett.
Im sure that Mike will modify his circuit so that it has hysteresis from 5.4V to 6.6V.
In that way the auto low cut off will reset to ON when the mains is restored.
OK.
Old 14th June 2009, 06:53 PM   #9
The circuit as presented the last time already exhibits some hysteresis, as defined by the 2.2meg feed-back resistor. It creates a nice clean switching threshold, and the circuit will not cut back in until the battery voltage is about 200mV higher than where it cut out.
The attached circuit as modified to increase its load switching capacity by replacing the PNP with a PFET. It will now switch an Amp or three. I also modified it so that it includes the explicit push button to restart it. Note that I lowered the estimated load being switched to 20Ω.
MikeMl is offline
Old 14th June 2009, 07:01 PM   #10
hi Mike,
My experience with SLA batteries shows that the battery will 'recover' to a voltage much higher voltage than 200mV, as soon as the load comes off.
I would predict the circuit will tend to repeatedly switch on/off, at the battery low point.
Old 14th June 2009, 07:19 PM   #11
Good Point! Either modify the circuit to increase the hysteresis or use the version with the push button, which will not start again unless the button is pushed.
MikeMl is offline
Old 14th June 2009, 07:53 PM   #12
Thanks you so much for your help on this. The push button idea is great! I will give it a try on breadboard as soon as poss and let you all know how I get on.
Brett.
oliverb is offline
Old 14th June 2009, 09:07 PM   #13
Quick question. The TDL431 is stocked with many codes after the 431. Can you tell me what type in your circuit so I can get the data sheet?
Thanks.
Brett.
oliverb is offline
Old 14th June 2009, 11:50 PM   #14
Here you go. I find these little buggers about as useful as 555s, so I bought 20 from Mouser in the TO-92? plastic transistor package.
MikeMl is offline
Old 15th June 2009, 06:05 AM   #15
Thanks again MikeMl.
oliverb is offline
acid, battery, discharge, lead, protection, sealed
EASY- Charge Sealed lead acid battery with benchtop power supply spitso General Electronics Chat 4 22nd May 2009 09:02 PM
Mounting sealed lead acid hantto General Electronics Chat 3 15th November 2008 10:40 AM
Sealed Lead-Acid Battery (recovery) arhi General Electronics Chat 25 25th May 2008 08:11 PM
sealed lead acid battery chargers ssylee General Electronics Chat 10 5th January 2008 03:36 AM
12v Sealed lead acid battery charger andi_n2004 Electronic Projects Design/Ideas/Reviews 1 27th April 2004 01:52 PM
