Old 14th June 2009, 05:43 AM   #1
Default Logic high/low
How do I use this photo interrupter circuit
Silicon Chip Online - Circuit Notebook
at 3 volt (without relay) to pull pins 12/13 (in12/22) of this IC
BA6845FS Datasheet pdf - Magnetic Disk LSIs > FDD stepping motor driver - ROHM
low when beam blocked and high when beam not blocked.
carlson is offline
Old 14th June 2009, 06:22 AM   #2
I'd wire it as in the train detector, but put a second inverter after the first. That would give you the high.
If you can move the load resistor to the collector of the photo-transistor, then you can do it with only one Schmitt inverter.
MikeMl is offline
Old 14th June 2009, 06:35 AM   #3
Can I do it without the invertor
carlson is offline
Old 14th June 2009, 06:51 AM   #4
Probably not, because the transition from on/off off/on will be not be a clean logic transition, will be too slow, and because of the low-gain optointerupter, will float around near the trip-point being modulated by 120Hz incident light.
MikeMl is offline
Old 14th June 2009, 07:02 AM   #5
terrific ta thanks
carlson is offline
high or low, logic
sending a constant LOGIC HIGH from pc to max232 qtommer Electronic Projects Design/Ideas/Reviews 6 11th June 2009 02:06 PM
5V Logic Level with High Current Suraj143 General Electronics Chat 11 25th September 2007 04:36 PM
7v low, 24v high to cmos logic? schrodingerscat Electronic Projects Design/Ideas/Reviews 13 24th July 2005 11:20 AM
Need to raise low voltage to logic high roffee Electronic Projects Design/Ideas/Reviews 1 25th February 2004 03:43 AM
logic output HIGH from 5V to 12V bogdanfirst General Electronics Chat 8 29th July 2003 01:49 PM
