I removed a small DC motor from a tape deck would like to use it to drive another tape unit. The motor has a small dynamo installed on it's shaft and it generates voltage as the motor runs. Since I need to control the motor as accurately as possible I thought to build a simple circuit that uses the voltage generated by the dynamo to control the speed of the motor (=feedback). Does anyone happen to have a circuit like this? The motor runs at 1V - 3V range and the dynamo generates 0.3V when the motor runs on 1.5V for example. I don't have much more info on the motor and no marking on it either.
| | #2 | |
Yes, I'll do that. I was asking mainly because I only know to construct a basic err amp with an OA and a voltage devider and the dynamo output is AC and I think that rectifing it might hurt the linearily of the amp. I think I may have used the word dynamo incorrectly and the proper name for the generator is an alternator (whoops).
| controlled, driver, motor, voltage |
| voltage controlled PWM help | kaido | Electronic Projects Design/Ideas/Reviews | 5 | 3rd June 2009 10:03 PM |
| HELP. Time Controlled Motor | theshoes | Electronic Projects Design/Ideas/Reviews | 4 | 5th May 2009 05:53 AM |
| Temperature Controlled AC Motor | bryan | Electronic Projects Design/Ideas/Reviews | 1 | 19th November 2003 12:02 AM |
| Voltage controlled amplifier | Jimbo | Electronic Projects Design/Ideas/Reviews | 2 | 20th October 2003 01:25 PM |
| pic controlled stepper motor | inverter | Micro Controllers | 2 | 13th June 2003 12:20 PM |
