Old 12th June 2009, 02:55 PM   #1
Default TTL and CMOS
hi, i am a student at WKC in my final year and am currently just finishing off my final project. i have built a fairly basic reaction timer that counts up in tenths of a second. i have used a mixture of CMOS and TTL chips in my circuit. not a good idea ,i know, but my circuit seems to work fairly well. will there be any long term deffects because of this?
LAU B is offline
Old 12th June 2009, 03:31 PM   #2
The noise margin will be affected at the interface between ttl and cmos, if not properly accounted for. So, the unit may fail intermittently, but there shouldn't be any long term effects or degrading.
BrownOut is offline
Old 12th June 2009, 08:02 PM   #3
The TTL high output level is not a full logic "1" for the CMOS. Thus the CMOS may draw more current then normal as the input PMOS transistor may not be fully off as it should be with a logic "1". (See Logic Voltage Thresholds for TTL, CMOS, LVCMOS, and GTLP IC's for a comparison of the logic threshold levels.) To avoid this you should have a pull-resistor (10kΩ or so) to +5V on all TTL outputs connected to a CMOS input.
Carl
Curmudgeon Elektroniker
crutschow is offline
Old 14th June 2009, 07:50 AM   #4
You should do proper interface between them to have no problem
And on the eighth day God said, "Okay, Murphy, you're in charge!"
www.pcbheaven.com
pcbheaven.com is offline
Old 14th June 2009, 08:42 AM   #5
The main thing when using CMOS is to be sure to tie unused input pins high or lower, never floating free. This applies even to unused gates in multi-gate packages. With TTL you could get away with unwired inputs floating high, even though it's not a recommended practice, however with CMOS it would cause gate oscillation and over dissipation of the package.
Lefty
Measurement changes behavior
Leftyretro is offline
cmos, ttl
cmos naik_mc General Electronics Chat 3 23rd January 2008 08:36 PM
Cmos To ttl Eng.Remon Micro Controllers 9 17th April 2007 09:41 PM
24v/CMOS/24v how???I svtiss General Electronics Chat 5 6th November 2004 06:55 AM
TTL o/p or CMOS o/p for different Vcc Eric Koh Micro Controllers 3 2nd June 2004 02:53 PM
TTL/CMOS hani_a General Electronics Chat 6 18th April 2004 06:48 PM
