Old 12th June 2009, 08:20 AM   #1
Default Stepper Motor Driver
Could someone please help me with the logic circuit required to drive a 3 volt 10ohm motor in a forward direction only via this IC
A relay will be used on the power input or output to control the motor with a photo interrupter unless the stop function is ultra easy via the photo interrupter controlling the logic stop mode
BA6845FS Datasheet pdf - Magnetic Disk LSIs > FDD stepping motor driver - ROHM
Many thanks in anticipation
carlson is offline
Old 12th June 2009, 11:17 AM   #2
Look at the first line of the truth table...It tells what pins need to be hi/lo to make the motor go forward......
Eccentric millionaire financed by 'er indoors
Chippie is offline
Old 12th June 2009, 11:21 AM   #3
What is the circuit to make the relevant pins go hi and lo
carlson is offline
Old 12th June 2009, 12:15 PM   #4
You need two switches as shown, - one connected to pins 4,5 and one to pins 12,13
Wp100 is offline
Old 12th June 2009, 12:39 PM   #5
So the Pins need to be switched to cause the motor to run and the speed depends on the rate of switching?
carlson is offline
Old 12th June 2009, 01:20 PM   #6
Using switches will send the motor at full Vcc speed.
If you want to control the motor speed then you have to use PWM or something similar - a way of sending switched pulses to the Driver chip.
Searching this forum on Stepper Motor Drivers will give you a better idea - a popular combination is the L297 logic chip with the L293/8 drivers
Wp100 is offline
Old 13th June 2009, 05:45 AM   #7
How do I use this photo interrupter circuit (without relay) to pull pins 12/13 (in12/22) low when beam blocked and high when beam not blocked.
Silicon Chip Online - Circuit Notebook
carlson is offline
Old 13th June 2009, 09:52 AM   #8
Hmm...No link!
Chippie is offline
Old 13th June 2009, 10:58 AM   #9
carlson is offline
driver, motor, stepper
Stepper Motor Driver magester1 Electronic Projects Design/Ideas/Reviews 10 10th February 2009 11:49 AM
Stepper motor driver Jabir Robotics Chat 46 19th December 2008 12:20 AM
I need a stepper motor driver! tj107us General Electronics Chat 8 9th February 2006 11:43 PM
Stepper motor driver ChArLyZzZ Micro Controllers 1 31st August 2005 12:46 PM
Stepper Motor Driver zhizhi16 Electronic Projects Design/Ideas/Reviews 1 29th April 2004 09:35 PM
