Old 12th June 2009, 07:32 AM   #1
Default dual 12v dc motors
quick question guys, I two identical motors and I want them to run at the same time and at the same speed. Can I use one speed controller to control both? they are 5 amp motors.
diy549 is offline
Old 12th June 2009, 07:42 AM   #2
Not if their shafts are not connected together. Differences in load and slight differences in motor characteristics will always cause one to run at a different speed from the other with the same input voltage.
Carl
Curmudgeon Elektroniker
crutschow is offline
Old 12th June 2009, 07:54 AM   #3
what if I used 2 speed controllers. Also its a gear motor, but I don't think that matters
diy549 is offline
Old 12th June 2009, 02:22 PM   #4
The second speed controller, though it might allow you to get the speeds close, if there in any changes in the loads, just adds in one more variable.
Ken
KMoffett is online now
Old 12th June 2009, 02:45 PM   #5
Depends on the type of controller. Some controllers are open-loop speed control, in which case you can get the two speeds close, but not exact.
Is there a digital tachometer on the motors? If the controllers are closed-loop speed control, then you can get them turning the same speed.
You could also run one open-loop, and then build a controller that "slaves" the second motor to the first.
MikeMl is offline
Old 12th June 2009, 06:28 PM   #6
So what are you driving That needs two motors?
If both motors are identical and have the shafts coupled together and are fed by the same power source they will act just like a 10 amp motor instead of a 5 amp motor.
I have seen industrial conveyors and process equipment do this with matched pairs of motors for loads that require a high capacity power source only part of the time. At light loads one motor is shut off and just free wheels.
"Issue a general safety warning. Then look the other way and allow stupidity the chance to eliminate itself." -- tcmtech
"Those who can, Will. Those who can't, will achieve positions of power over those who can and then promptly stop them." -- tcmtech
"Your impossibility may just be my day to day routine." -- tcmtech
tcmtech is offline
12v, dual, motors
Dual fet Gregory Datasheet/Parts Requests 1 2nd April 2008 10:54 AM
PWM control of BLDC motors (brushless DC motors) jhanus Micro Controllers 6 1st October 2007 05:32 PM
L298 for 3V motors of tamiya dual gearbox ? pkshima Robotics Chat 5 13th June 2007 05:11 AM
Dual RS 232 in PIC dreamproject Electronic Projects Design/Ideas/Reviews 1 11th January 2006 12:45 PM
shunt motors, series motors...dc motor fabbie General Electronics Chat 5 19th December 2004 12:27 AM
