Hey all, I have 2 - 12VDC fans (the same kind that ventilate a tower pc). I want to vary the speed of the fans to change the cfm output. Is there a simple circuit I can use, or is it as simple as a var resistor, since the current draw is so low? Thanks. | |
Most of those fans use hall-effect sensors embedded in the stator to sense the rotor position in order to switch the stator windings. They do not work at all if the voltage is reduced below a fixed threshold. I think you will have to obtain special fans which are designed for speed control. Hook your existing fans to a variable bench power supply and see what happens. Last edited by MikeMl; 10th June 2009 at 06:23 PM. | |
would this circuit do the job?
__________________ And on the eighth day God said, "Okay, Murphy, you're in charge!" www.pcbheaven.com | |
| | #4 | |
Thanks, and thanks to the guy who designed the circuit. Props guys. | ||
Just drop the input voltage. I have yet to find a 12 volt computer fan that wouldn't spin at less than 3 volts. Just use a three pin adjustable voltage regulator (LM317 or similar) to change the fans input voltage. Three components and your good to go. I have seen and tried the PWM method and very few fans I have like it. Linear voltage regulation is better suited to small fan operations. And yes its less efficient than PWM or SMPS but if you cant spare an extra watt you shouldn't be using this size or type of fans in the first place!
__________________ "Issue a general safety warning. Then look the other way and allow stupidity the chance to eliminate itself." -- tcmtech "Those who can, Will. Those who can't, will achieve positions of power over those who can and then promptly stop them." -- tcmtech "Your impossibility may just be my day to day routine." -- tcmtech | |
| 12vdc, fan, output, variable |
| Regulated 12VDC 5A output power supply? | shaneshane1 | General Electronics Chat | 8 | 27th December 2007 02:20 AM |
| D/A output buffer with variable gain (Vpp=0..20V) | klausbock | Electronic Projects Design/Ideas/Reviews | 2 | 4th July 2007 10:56 PM |
| Oscillator with variable output amplitude | AlphaRugal79 | General Electronics Chat | 11 | 28th February 2007 08:40 AM |
| Variable current output... | Night Thrasher | Electronic Projects Design/Ideas/Reviews | 2 | 19th March 2004 03:21 PM |
| 12V variable amp output project | phad3r | General Electronics Chat | 3 | 12th January 2004 06:19 AM |
