Hell all new here. I am designing a seven segment LED clock (yes a clock again lol) but am stuck with a MOSFET. What it is, is that am using an UDN2981 (high side driver array) and will be using PWM on the 6 CA seven segments using the PWM pin of the PIC16F877. I will be PWM'ing the VCC pin of the UDN2981 With a MOSFET (12V connected to the source and the drain connected to the VCC pin with the gate connected to a BC847 with a 1K resistor). My problem is that am not sure which type of MOSFET to use ie n-channel or p-channel. I think i should be going for the p-channel and use a BC847 on the MOSFET gate whit the BC847 connected to the PIC's PWM pin. So could anyone tell me if my thinking here would work providing i select the correct resistors to saturate the BC847 (to use as a switch). All so is the current flow in MOSFETS bi-directional. Hope i have gave you all enough info. Regards, AHughes1984. | |
| | #2 | |
__________________ SUB-20 Multi Interface USB Adapter I2C,SPI,GPIO,RS232,RS485,Ir,LCD http://www.xdimax.com/sub20/sub20.html | ||
| 7segment, mosfet, pwm |
| LM35 7segment output w/o uC | X4ce | General Electronics Chat | 12 | 12th February 2009 07:43 AM |
| dual 7segment? | silvarblade | Datasheet/Parts Requests | 3 | 3rd September 2008 07:10 AM |
| is resistor necessary for driving 7Segment? | Hesam Kamalan | General Electronics Chat | 8 | 22nd May 2008 02:35 PM |
| getting a 0 on the 7segment using a 4511 | rebirth of sands | General Electronics Chat | 1 | 24th January 2008 12:09 PM |
| 74LS47 drives 4 7segment display. | ah_Hui | General Electronics Chat | 6 | 9th March 2004 11:59 PM |
