Old 27th March 2003, 05:38 PM   (permalink)
Default Help with a PS2 amplifier
I am trying to build a voltage amplifier fot boost the PS2 voltage of 5v to 12 volts. I want to put neon in me keyboard but don't want a seperate wire for the power supply. Can anyone help?
Sinni
Sinni is offline   Reply With Quote
Old 27th March 2003, 05:42 PM   (permalink)
how much current do you need for the neon?
an invertor can be as simple as a 555 feeding a voltage multiplier or as complex as a boost regulator based on say a 78S40......... 8)
Chippie is offline   Reply With Quote
Old 27th March 2003, 05:57 PM   (permalink)
Well i'm trying to connect StreetGlow's Hotwires http://www.streetglow.com/site/auto7.htm. After looking through their FAQ the 20" accent tube is about 1/2 amp. So guessing from that i would have to say the amperage should be pretty low.
Sinni
Old 27th March 2003, 06:23 PM   (permalink)
So you need a switcher that will provide 12vdc at around 500mA.......from a 5vdc source........Take a look at National Semiconductors web site for applications for the LM2577 switcher.......that should do the job with a low component count
post up if you need any more help
Old 28th March 2003, 12:19 AM   (permalink)
That should look prety cool when you finish. The stores here are selling lots of low voltage neon and LED components for the inside of computers and the auto stores are selling neon like the add you posted. I never heard of adding to the keyboard though. If you do it without adding any wires will be a real trick. Hope you will post a picture.
Gene is offline   Reply With Quote
Old 28th March 2003, 06:52 AM   (permalink)
Don't forget to check PS2 5V output current capability.If You need 500mA on 12V boost reg.out, it sucks about 1,2A from 5V.
Maybe the circuit must be screened to avoid interference with data and clk signals.
As Chippie wrote, LM2577 the best choice, i also recommend it.
Sebi is offline   Reply With Quote
Old 28th March 2003, 11:05 AM   (permalink)
maybe i am wrong but isnt the current available on the PS/2 port limited to 500mA? so if you want 500mA for 12V you need .5 x 12/5=1.2A
how are you gonna get that from a PS/ 2 port?
bogdanfirst is offline   Reply With Quote
