| New Member | Hi there, I got question here, is it possible to build a rocket by using magnetism concept? The rocket doesn't have to fly very high up, that means can fly inside a hall is more than enough. Please help me with any ideas that anyone have in mind. I have thought of a coil gun might be similarly to the concept of it. I would like anyone whom might be helpful enough to give me information more on the coil gun and how to construct it.Thank you. |
| Experienced Member | Interesting subject :-) I can't really see how you could "load" the rocket with magnitism, but you could sure hold a loaded rocket down by using some kind of electric magnet, and then releasing it by a switch. That would be trivial to do even with a very small power supply (like a 1.5V battery)... but maybe that wasn't what you had in mind? And by "not loading" I mean using home brewed solutions, not at goverment level :-) //Albert "thec" Sandberg |
| New Member | well couldn't u put the rocket in like a tube with a lever on it, preventing the rocket from leaving the chamber, and use electro magnetism to build up a magnetic force great enough, then the lever is hit to release the rocket, and the magnetic force "pushes" it out of the launch tube? just a thought I did a similar project attracting a nail from 2 feet away using magnetism and some electrical current, u'd do the opposit, more like repulsion, it should be possible, isint that hor electric nail guns work? |
| Experienced Member | Hmm.. sure you could... two poles of the same don't match.. so.. one side of the electric magnet could be used as a "loader" so to speak. Hmm.. try it out and give me a review :-)) //Albert "thec" Sandberg |
| Super Moderator | Depending on your concept of a 'Rocket'... If a catapult firing a projectile is considered to be a rocket launcher then a system of two opposing magnets would be feasable (though the 'square-law' loss of field intensity as distance between the magnets increases would limit the useful energy imarted to the rocket). If a linear motor is constructed in a launch ramp or guide tube then it would be possible to 'push' the rocket for the full length of the ramp/tube and so give it more 'thrust'. Something like this appeared in 'James Bond' film - shooting a metal tray along a horizontal track to decapitate a dummy. For this to work the rocket must contain metal to establish the inducance-driven 'rotor' magnet. The launch ramp/tube would then contain a series of adjacent coils, powered in sequence to create a series of magnetic ripples along the ramp/tube. Don't ask for details -- I don't know! Maybe the idea could be what you are after? A photo (of sorts) is available ... http://www.ksky.ne.jp/~tom/intro3.html |
| New Member | What mechie alludes to is called a "rail gun" Fire a sequential aray of ele mags to pull a farris metal projectile. The firing order is not linear. Each mag should be fired in a shorter time delta than the last one. This will accerlate the projectile. Timing IS everything. Use large caps to dump current into the coils. (more ideas? ask) THIS IS NOT A TOY! If built only half right it would easy to punch a hole in the roof of your "hall". A device like this could KILL! The eletricty in this project could KILL! Hey, but have fun. |
| New Member | here is a page i found that could quite useful as you could modify the rail or use it as some kind of guide to slot your rosket into http://members.tripod.com/extreme_skier/railgun/ have fun and dont hurt anyone .... unless they really really deserve it |
| Magnets and Electromagnets | ElectroMaster | Electronic Theory | 11 | 27th November 2007 02:31 PM |
| Magnetic powererd flashlight | JJ91284 | Electronic Projects Design/Ideas/Reviews | 6 | 24th August 2004 02:57 AM |
| Need Help, Magnetic Field Detector | JK108 | Electronic Projects Design/Ideas/Reviews | 4 | 30th March 2004 06:50 AM |
| Magnetism and Magnetic Circuits | shermaine | General Electronics Chat | 2 | 13th February 2004 01:02 AM |
| magnetic field measurement with an RF oscillator | Joop | Electronic Projects Design/Ideas/Reviews | 3 | 11th July 2003 07:57 AM |
