Hello all, I'm a PhD Physiology student from Manchester University and have an idea for measuring tissue density using a laser, a light dependent resistor and a 741 op amp. It is probably worth saying that although I am fairly familiar with electronics, I am by no means competent....and basically I would be very greatful to know your thoughts on this idea and whether it would work.... In essense i intend to shine a 1mW laser through very thin sections of tissue on to an LDR. If tissue density decreases, more light will get through and therefore the LDR resistance will decrease. I want to amplify this change in resistance/current somehow and and am thinking of a 741 op amp. The output of the 741 would then go into a computer via Powerlab which would record the fluctuating output. The laser and LDR will remain in a fixed position and the tissue would be moved within the beam. Any change in tissue density within the sample should I guess result in a fluctuating current input into the 741 I have a few questions: 1)Would an LDR between the +ve rail and 741 input work? 2)Will the output from the 741 directly correlate with the input? 3)Will this work?! Sorry if I sound a bit thick, cheers in advance. | |
Please use a good op-amp and not the 741, which dates back to 1968. There have been improvements in 41 years....... LDRs are quite sensitive, and you might not even need an op-amp at all. If the change in light is very small, you can amplify it with an op-amp, but you need to know what the zero point is. In the simplest form you feed the inverting input of the op-amp from a potentiometer and manually adjust the zero point. You need some negative feedback on an op-amp or it becomes a switch with either zero or maximum output. I suspect LDRs are fairly temperature dependent. For best sensitivity, you need to turn the laser on and off (an optical chopper can do that) and you have a phase sensitive detector to give the output signal.
__________________ http://nottheboss.wordpress.com/ | |
| | #3 | |
Regarding the zero point, I think Powerlab will sort that out as we can set a base line on the program plus the experiments will always be carried out in same conditions i.e. in the dark - probably. So far I have got to the stage below - i am quite positive I need some more components in there but really havent a clue what - any suggestions? R3 is supposed to be the LDR (wasnt a symbol for it on the program) Cheers | ||
| 741, amp, ldr, level, light, monitor |
| Low Fuel Level Light | matt_hau | General Electronics Chat | 7 | 24th March 2009 09:00 AM |
| Newbie: Motion/Light triggered fog machine, light flash and sound | silentalibi | Electronic Projects Design/Ideas/Reviews | 0 | 6th March 2009 10:02 AM |
| Water level Monitor - Real time | krishtriram | Electronic Projects Design/Ideas/Reviews | 11 | 9th November 2008 08:28 AM |
| When my laptop is charging and I hook my monitor up to it, the monitor starts getting | Qaiphyx | General Electronics Chat | 11 | 3rd August 2008 11:56 AM |
| Converting from guitar level to line level | joecool85 | General Electronics Chat | 10 | 23rd March 2006 02:04 PM |
