i have an lm741 in my project and i am wondering if i can use +9,-9 instead of the maximum rating???also i have an external -12v source and i am wondering is it as simple as using an lm7809 to bring this to -9v or would i have a problem with over heating?? thanks | |
| | #2 | |
![]() A 741 will work OK with +/-9V supplies. The Vout will only swing to about +/-2.5V of the rail voltage, using +/-9V this will be approx +/-6.5V
__________________ Eric " Good enough is Perfect " I will NOT answer PM's requesting technical help, please use the Forum PIC tutorials: Nigel's www.winpicprog.co.uk/ Bill's: www.blueroomelectronics.com/ Last edited by ericgibbs; 9th June 2009 at 12:15 PM. | ||
The supplies don't need to be equal, so you can also run it from +9V and -12V without problem, eliminating the need the the lm7809.
__________________ Carl Curmudgeon Elektroniker | |
You would need an LM7909 to bring a -12V input to -9V output. An LM7809 is for +9V output. creakndale | |
| regulator |
| regulator | tom_electronic | Datasheet/Parts Requests | 4 | 19th May 2008 05:38 AM |
| Convert voltage regulator to constant current regulator? | goldserve | Electronic Projects Design/Ideas/Reviews | 10 | 11th September 2006 06:39 AM |
| SCR regulator? | rshankar86 | Electronic Projects Design/Ideas/Reviews | 4 | 27th January 2006 02:35 PM |
| 6v Regulator | BansheePilot | Electronic Projects Design/Ideas/Reviews | 5 | 27th February 2004 09:28 PM |
| Need 10v Regulator! | Squintz | Datasheet/Parts Requests | 1 | 3rd February 2004 02:53 PM |
