Old 8th June 2009, 02:41 PM   #1
Default iPod audio amp
hi, firstly, nice forum iv been on it about an hour already :P
ok, so im building a simple stereo audio amp for an ipod inside an ipod - like the ones here:
Speaker made from old iPods - Hacked Gadgets - DIY Tech Blog
The amp i am using is the TDA2822m.
i accidentally pressed enter so the thread was posted incomplete.
continuing on... i have used 2 tantalum caps in place of 2 electrolytic caps both are 100uf. The amp currently does not work, is it because of the caps?
-Simsy- is offline
Old 8th June 2009, 04:09 PM   #2
If your capacitors are connected with the correct polarity in the circuit shown in the datasheet of the TDA2822M and using the pcb layout shown in the datasheet and if the battery voltage is 4V to 7V then the amplifier should work fine.
But since you did not post your schematic here then we do not know what you have done.
audioguru is offline
Old 8th June 2009, 04:37 PM   #3
thanks audioguru
i have used the circuit shown on the data sheet "test circuit (stereo)" http://www.datasheetcatalog.org/data...onics/1464.pdf
im using a test voltage of 6v
and i dont have a pcb as they werent available which made things a bit tricky (couple of bridges) its probably the polarity. i have the arrows flowing from positive to negative. (conventional flow is used isnt it?)
this is my first actual circuit outside dodgy parallel and series differentiation types at school so go easy :P
-Simsy- is offline
Old 8th June 2009, 05:26 PM   #4
The amplifiers might oscillate if you do not make them on a compact pcb with a layout like shown in the datasheet.
ST Micro show capacitors with an open line for the positive terminal and a closed line for the negative terminal.
Tantalum capacitors have the positive terminal marked with a "+" sign. Electrolytic capacitors used to be marked the same and are shown with the positive terminal marked with a "+" sign on schematics but newer ones have an arrow pointing to the negative terminal.
I marked the positive terminal on each capacitor for the stereo amplifier.
Old 9th June 2009, 11:50 AM   #5
yep, all the caps are correct. my dads multimeter recently broke so i used an LED to see if there's any current but it wouldnt light up when placed upon the power supply pin (2) and the ground pin (4) or between speaker output (either of them) and ground. there was an active input. Does it really need no negative voltage input? thanks
-Simsy- is offline
Old 9th June 2009, 01:20 PM   #6
If you placed an LED between the power supply pin 2 and the ground pin 1 of the IC then the LED is blown up without any current-limiting resistor in series with it.
The LED would also blow up and maybe the amplifier iC might also blow up if you connected the LED between the output pin 1 or pin 3 and ground without any current-limiting resistor in series with it.
Your dad's multimeter would blow up if you connected it to the power supply like you connected the LED. It short-circuited the power supply.
Or your 6V power supply or battery is dead.
The TDA2822M IC does not need a negative supply voltage. The negative wire of the power supply connects to ground.
Old 9th June 2009, 02:11 PM   #7
Here is a picture i took of the amp. I traced a couple of branches to make them easier to make sense of. Can you see any flaws?
-Simsy- is offline
Old 9th June 2009, 02:28 PM   #8
The camera on your cell phone is so bad that I cannot see anything on the photo.
If your speakers are 8 ohms then the very small value of the 100uf output capacitors cuts all bass frequencies below 200Hz.
Old 9th June 2009, 02:49 PM   #9
i dont actually know the resistance of the speakers as like i said the multimeter is broken and they are unmarked because they're salvaged from an old vaio. How would i prevent the mangling of my tunes? here's a better quality picture.
-Simsy- is offline
Old 9th June 2009, 03:54 PM   #10
The photo is much better but I still I cannot see how you wired the perf board.
Old 10th June 2009, 05:44 AM   #11
heres the better quality pic with wiring marked
-Simsy- is offline
Old 10th June 2009, 02:30 PM   #12
I cannot see what is connected to what.
For such a simple circuit I do not understand why you have wires crossed and all over the place.
Old 10th June 2009, 03:35 PM   #13
i cant really show you any clearer. I'll show my physics teacher tomorrow and hopefully he'll be able to identify the problem. All the bridges are due to size limitations and the lack of a pcb. I saw a method of making pcb's on the forum so i'll look into that.
Thank you for your help
-Simsy- is offline
amp, audio, ipod
Stolen Ipod =( Ipodtouchless Electronic Projects Design/Ideas/Reviews 63 6th May 2009 07:47 AM
ipod matty5654 Electronic Projects Design/Ideas/Reviews 2 21st July 2008 01:01 PM
iPod Innovative General Electronics Chat 2 30th June 2007 08:02 PM
9v usb ipod charger help Cameron589 General Electronics Chat 11 22nd April 2007 03:25 PM
FM Transmitter, ipod, ipod charger interference? adamthole General Electronics Chat 1 20th December 2005 01:53 AM
