Old 23rd May 2009, 11:29 PM   #1
Default simple oscillator formula
Hello, I am working on a simple oscillator that uses two inverter gates, a resistor and a capacitor. I planned this out a while back, but I cannot find the formula I used to calculate the frequency. I also can't find anything online that resembles the circuit that I am using and also gives a formula for it. Can someone help me out here? I attached the schematic.
Thanks,
Josh Clark
Last edited by soadrage7654; 23rd May 2009 at 11:31 PM. Reason: error in schematic
soadrage7654 is offline
Old 24th May 2009, 01:06 AM   #2
http://www.musicfromouterspace.com/a...h/mmlogic.html
You may want to add one more inverter as a buffer to the LED separately from the feedback or the LED loading will effect the oscillator frequency, how much I don't know.
straight answer, har har."
Sceadwian is offline
Old 24th May 2009, 03:28 AM   #3
I would assume that the following would be correct:
F = x/(RC)
Just build the circuit and measure the frequency. Then you can calculate x. Then you can calculate the rough frequency for any RC.
dougy83 is offline
Old 25th May 2009, 05:52 AM   #4
Ok thanks for the suggestion. I was going to use that as a last resort, but I guess it's the only choice now.
I just thought it was weird that I had a formula for the frequency when I first planned it out, but I couldn't find it later so I wanted to check to see if anyone else happened to know it.
Old 25th May 2009, 06:14 AM   #5
Actually, before you give up, have a look at
Square wave oscillator (2)
You will note that there is an extra resistor used, Rp, to 'protect' the CMOS input. It also has the added function of preventing the capacitor from being discharged through the CMOS input diodes (this affects the duty cycle & frequency, so the above f=x/r/c is no good due to the diodes affecting the timing)
dougy83 is offline
Old 30th May 2009, 12:20 AM   #6
Rp is just a high value resistor 100k to 1M is normally good enough.
if I know the answer.
Hero999 is offline
Old 30th May 2009, 07:19 AM   #7
Someone else asked about this and we talked about it can came up with
very good formulas. If someone could find it, it is here on this site somewhere.
MrAl is offline
formula, oscillator, simple
Why this simple oscillator/flasher doesn't work? RussellH Electronic Projects Design/Ideas/Reviews 15 10th April 2009 11:13 PM
Simple BP Filter, Cap Formula. chemelec Electronic Projects Design/Ideas/Reviews 6 27th November 2005 02:40 PM
Simple accurate 1s oscillator? Sawblade General Electronics Chat 6 20th January 2005 05:14 AM
Simple crystal oscillator circuit canadianpoet2012 General Electronics Chat 10 1st July 2004 04:37 AM
Simple oscillator circuit needed 1Steveo General Electronics Chat 3 16th May 2004 10:49 PM
