I need a vccs with input range of 0-5V and output current range of 0-5A. Can I use two op-amps with a BJT in the feedback path which is suggested by some website? What are the main considerations in the VCCS design? If the above topology is ok, what are the requirements of the op-amp and BJT? Thank you very much. | |
Please post the schematic. It sounds like a good way of doing it.
| | #3 | |
You might want to add an amplifier on the sense resistor so you can limit the drop-out voltage. If you use a 100mΩ resistor for the sense, an op-amp with a gain of 10 would enable you to use it for 0-5V to 0 to 5A conversion with a maximum voltage loss of 0.5V.
For higher currents I'd definitely go with Hero's suggestion of an extra opamp so you can keep the sense resistor small. Aside from wasting less power as heat the lower heat in the sense resistor means it will be more linear, big sense resistors will also drop a lot of voltage so the whole circuit will be effectively DC biased above ground.
| controlled, current, design, source, voltage |
| Help:Digitally controlled current source | abicash | Electronic Projects Design/Ideas/Reviews | 20 | 4th May 2009 08:07 AM |
| Voltage controlled current source | Analog2008 | Electronic Projects Design/Ideas/Reviews | 2 | 2nd January 2009 08:54 AM |
| Need Help Design Current Source | leofur | Electronic Projects Design/Ideas/Reviews | 8 | 7th March 2008 10:05 AM |
| help to design current source | mohammed elzaq | General Electronics Chat | 1 | 2nd October 2005 12:41 AM |
| voltage and current source | Gaston | General Electronics Chat | 14 | 8th March 2005 06:46 AM |
