Old 18th May 2009, 12:35 PM   #1
Default Flight Control Grip Movement/Position Sensor
When it comes to detecting movement/positional data I found a pretty easy method that works a treat - light. Sure it is defendant on having a sealed enclosure for the sensor itself, but let me explain a little more..
A work colleague recently had a dilemma with his flight sim flight control grip that he is building (an F16 cockpit) - they are a high G model with limited movement, about 10mm if that full scale deflection for either axis. Here's the replica;
The real life grip adapter utilities a near inflexible force transducer to provide X/Y positional data. It also costs a lot of $$$. A cheaper DIY approach was made and it worked a charm!
Here's the underside of the DIY adapter;
A high grade aeronautical silicon applied to the upper side of the adaptor (not shown) ensures incredibly tough movement resistance and high tension springs (shown above) are loaded just before the tension point allow quick/accurate returns to zero upon release. From there, a high brightness LED is mounted within the square tube, providing a bright light shadow that directs down. The sensor consisted of two LDR's that were heavily masked to provide a means for X and Y data capture;
You might see how this is working already, if not then read on.
The light pattern is directed down, and biased so that it lay directly in the center of either sensor. From there, the limited movement of the control grip allows the light pattern to move from one side of either LDR to the other without physically reaching the edges.
The square sensor and light pattern ensures that if the Y axis is moved directly up/down, the X axis will maintain the same amount of "light". The same concept applies for X axis movement. Here's the light pattern and sensors at work with the side panel off (it is completely enclosed during normal operation);
The program for this application goes into quite a few good little features such as detecting the min/max voltages, setting Vrefs to ensure max resolution and bubble sorted sampling along with various other controls being handled at the same time. I find it takes away from the concept at hand which I thought was share worthy!
Sure the results are non linear, but that too is accounted for within the program. On top of that, most HOTAS applications will allow joystick calibration etc to suit the characteristics of different aircraft. The completed grip assembly;
digital-diy.com - Hobby microcontroller projects and tutorials. Assembly, PICBasic and C examples.
gramo is offline
Old 18th May 2009, 01:16 PM   #2
What the heck are you building, a backyard jet fighter? That thing looks like it's bomb resistant =)
straight answer, har har."
Sceadwian is online now
Old 18th May 2009, 02:31 PM   #3
Hi Graham,
Saw this on your site. WILD! - no that's not an acronym
I'd love access to his sim.
Perhaps McDonnell Douglass would be interested?
EDIT: Whoops, that would be Lockheed Martin.
It was the F15 that McDonnell Douglass did.
BeeBop is offline
Old 19th May 2009, 07:48 AM   #4
It is a little sturdy - may as well do it right the first time around!
I'm in awe of some of the other avionics sim packages he has self-developed. Complete, functional CNI panels & displays. We're both avionics technicians though, which does help out
gramo is offline
Old 19th May 2009, 08:48 PM   #5
Post some links to what you guys are talking about, I'm curious.
You'll get no complaints from me gramo, I'm a big fan of overbuilding.
Old 19th May 2009, 09:34 PM   #6
Check out some of these:
Google
BeeBop is offline
control, flight, grip, movement or position, sensor
Movement Sensor jsjackson General Electronics Chat 17 25th May 2009 04:00 AM
direction movement sensor circuit kgrj Electronic Projects Design/Ideas/Reviews 1 20th April 2009 11:47 PM
please help! Need help making electric eye position sensor. Pomz23 General Electronics Chat 1 19th September 2008 02:16 AM
sensor for rapid eye movement.. beginner Wan Electronic Projects Design/Ideas/Reviews 8 27th October 2007 05:54 PM
RC Plane Control Surface Movement DigiTan Robotics Chat 7 30th April 2005 10:13 PM
