Hi, everyone. Since the charge pump in the market has limited output current, around 100mA, this will be the problem to power the power hungry devices like amplifiers. I had modified the circuit and it seems can work. I'll use 2 D type dry cells to power the circuit. Please give me some suggestions because I don't know whether this circuit can work or not. | |
1.5V dry cells quickly drop to 1.2V each so the charge pump will have a 2.4V supply. The transistors have a voltage loss of 1.4V and the diodes have a voltage loss of 1.4V so the output voltage will be less than the input voltage. You made a heater.
| charge, circuit, current, increasing, output, pump |
| Arbitrary Charge Pump IC | dknguyen | Datasheet/Parts Requests | 4 | 2nd March 2009 03:29 AM |
| increasing output current | neilxavier | Electronic Projects Design/Ideas/Reviews | 23 | 20th August 2008 06:45 AM |
| Charge Pump reccomendation | Krumlink | Electronic Projects Design/Ideas/Reviews | 16 | 13th August 2008 12:59 AM |
| increasing output current of 7805... | ikalogic | Electronic Projects Design/Ideas/Reviews | 17 | 14th April 2007 04:55 PM |
| switched cap charge pump | GoKid | General Electronics Chat | 2 | 16th June 2006 03:07 AM |
