Old 13th May 2009, 06:18 AM   #1
Default Kooky?: Replacing battery power with leads...
Well, my latest half-baked idea, curious to know if I'm off-track. Should be an easy answer. :-)
I have a number of devices that take batteries, and I'd like to avoid purchasing batteries (even rechargeables).
What I'd like to do is wire leads into the contacts of the device(s) going through a simple circuit from an AC/DC converter wall wart.
I'm figuring that an e.g. 2-AA battery compartment wants 3V at whatever current (I'm assuming my AC/DC converter will have ample current compared to batteries?).
I'm figuring that the converter, say it's putting out 9V, needs a voltage-dropping resistor (which wastes power/makes heat?) or a DC voltage converter (which, if cheap, makes messy/noisy power and also isn't too efficient?) to get to 3V.
I'm figuring that I can use a pair of dead batteries with the leads attached to the ends (one +, one -) and the other ends of the batteries covered with non-conductive material (to prevent short circuit), so I have an easy way of getting the leads down into the battery compartment to their destinations.
Curious to know if those assumptions have anything to do with reality, and the best way to achieve the desired voltage?
There's probably a product for this out there? I like to DIY, especially because I have a pile of various DC adapters.
Thanks a lot!
-C
chconnor is offline
Old 13th May 2009, 08:45 AM   #2
Something like that.
This depends on the powered device and of course the converter. As a starting point, check the label on the converter.
Depending on the device you're powering, either option may be effective. If the device has a low current consumption, then a linear regulator is fine. If current is higher, then you may want to put the regulator on a heatsink or use a switch-mode supply (which is more efficient unless set up incorrectly).
Switch mode supplies will have some ripple, but if this is a problem, follow it either with a filter or a linear regulator.
dougy83 is offline
Old 13th May 2009, 09:30 AM   #3
Dead batteries eventually leak and do bad things. Mostly make a mess, which is difficult to clean out. Use some plastic dowel and a couple of screws. Works pretty well, screws hold the wires, and make good terminals. You can add a washer or two if you cut the dowel too short for a nice fit...
Solder the leads directly, or add a socket if you have room...
HarveyH42 is offline
Old 13th May 2009, 10:33 AM   #4
Default Ok.
Thanks folks. Good to know I'm on the right track, or at least that it's possible.
Sure sure... As a ballpark, I'm talking about converting something like a 1 or 2A 9V converter to 3V to run a digital camera (no power cable for the camera, and it'll be doing a long time lapse.)
I guess part of the challenge is that battery-powered devices usually don't list their current draws... are there any kind of rough numbers, like maximum realistic draws off a couple of AA batteries for regular consumer electronic equipment?
Ok, so it sounds like the first choice is a properly-spec'ed switching regulator... I'll post more questions after I've done some homework...
Thanks very much!
-c
chconnor is offline
Old 13th May 2009, 10:50 AM   #5
I'm shamelessly gonna bump your thread with a link to mine! I'm wanting to do something quite similar!
I thought about doing something like your idea, but then decided i'd prefer not to have another plug in the wall.
Spatie1982 is offline
Old 13th May 2009, 04:19 PM   #6
Anything that runs of 2 AA alkaline batteries is not going to draw anywhere near 1A of current.
If there is no power jack on the camera, then I would use a linear regulator. The designers may have made the assumption that it would only ever be powered by noiseless batteries. Putting a noisy SMPS into the equation might cause some issues. In this case, using a low-noise linear regulator would be much better. Since you are using mains power anyway, efficiency at these levels of power is not a concern.
You could build the regulator/filter right in the battery compartment and add a power jack to attach the wallwart to.
smanches is offline
Old 4th June 2009, 02:14 AM   #7
Default How about this...
Ok, thanks for all the input.
What say ye about this schematic? I don't want to give you the impression that i know what i'm doing or anything, but this seems to fit the bill...
I assumed that an LM317 qualifies as a low-noise voltage regulator... I actually ordered a LM150 (not cheap, eh?) just to have the option of higher current outputs.
This schematic was largely based on this project: Replace the battery on a desktop gadget with USB power
The idea here is to have a tunable voltage so I can simulate one battery, two, etc.
Here's a question, though: some devices use multiple batteries in parallel, no? E.g. I can pull one of two batteries out and the device still works. Is there some easy way to figure that out, per device, so I can present it with the proper voltage and fake-battery rigging? I guess I can always do just that: take one battery out and see if it still runs (on a single fresh battery)...
Thanks!
-c
Kooky?: Replacing battery power with leads...-voltagereg.png
chconnor is offline
Old 4th June 2009, 02:50 AM   #8
The instructable and the last circuit are wrong.
The important capacitors are missing (they are not optional) and the value of R1 is too high. R1 must be 120 ohms for an LM317. A more expensive LM117 can use 240 ohms. When the value of R1 is too high then the output voltage rises when the load current is low.
audioguru is offline
Old 4th June 2009, 03:07 AM   #9
Aha... I'm very uninformed here, but, doesn't:
http://www.national.com/ds/LM/LM117.pdf
...show (on page 21, using an LM317) an example of using a 240 ohm R1? Maybe "Rs" changes the game in that schematic...
In general, doesn't the equation apply?: 1.25*(1+R2/R1) ? The PDF just doesn't seem to mention anything about 120 (although it pops up in one schematic), but of course I'm more likely to listen to a real person over a PDF. :-)
Or maybe what you're talking about is the ground-level reality of using these things as opposed to the graphs in the spec... or at least the ground-level reality of using these in low-current load situations.
Did i get the capacitors right in my schematic? They are referred to as optional in the PDF a couple times, but maybe that's a generous "optional"?
I have an LM150 coming in... 240-ohm R1 appropriate for that?
Thanks for setting me straight!
-c
chconnor is offline
Old 4th June 2009, 04:00 AM   #10
The minimum load current for an LM317, LM338 and LM350 is 10mA. When R1 is 120 ohms then its current is 1.25V/120 ohms= 10.4mA. It provides enough load current without any other load.
The minimum load current for the more expensive LM117, LM138 and LM150 is 5mA so the value of R1 can be as high as 240 ohms.
The battery charger uses 240 ohms for an LM317 because there is always a load current that is enough to hold down the output voltage.
Page 8 of the datasheet for the LM317 describes the output voltage rising when the load current is not high enough.
Old 4th June 2009, 04:44 AM   #11
Tacky Tacky tacky
microtexan is offline
Old 4th June 2009, 10:12 AM   #12
Ok, thanks for the info. This all is clearly beyond my partial understanding of the situation. but I understand what you're saying.
So, do I infer that I need at least 5mA drawing on the output side of my LM150 for the voltage to be appropriate? It would seem that this would then be an inappropriate circuit to simulate a 1.5v single AA battery or 3V with two of them in series, given that most devices are going to pull a lot less than that 5A (given what a previous poster wrote)?
Further, will I be able to test the output voltage with a multimeter to "tune" R2 if the output is unloaded, and if not, will I be able to tune the circuit accurately at all?
Thanks again,
-c
chconnor is offline
Old 4th June 2009, 10:30 AM   #13
The 120 ohm resistor takes care of the loading. The load current with a 120 ohm resistor is 1.25/120 = 10mA, which is fine.
Yes, use a multimeter to set the output voltage. It will be accurate.
dougy83 is offline
Old 4th June 2009, 09:52 PM   #14
Default getting there...
@audioguru - just out of curiosity, was that page 8 of the link I provided, or a different data sheet? I couldn't find a graph that looked applicable on page 7 or 8...
Ok, so if I'm getting this, the level of R1 adjusts the amount of load that the output will see without any actual load attached, and this is used to make the output voltage predictable/even. The lower R1 value means higher load, as audioguru explained. But he also said I could use a 240 with the LM150... does that sound right? Or should I use a 120 for some reason? I ask because the 240 ohm resistor is coming in the order I made (including the LM150).
And since .01*1.25 = .0125, a 1/4 watt R1 should be plenty, yeah?
Great.
Thanks again!
-Casey
chconnor is offline
Old 5th June 2009, 12:20 AM   #15
Your datasheet is from 2008, mine is from 2004 and they have different page numbers. The written description of the output voltage rising is on page 7 of your datasheet.
Yes, the LM150 needs a minimum load current of 5mA. 1.25V/240 ohms= 5.2mA which is fine.
Yes.
battery, kooky, leads, power, replacing
Leads Help biferi General Electronics Chat 32 28th October 2008 02:58 PM
How to bend IC leads pkshima General Electronics Chat 21 21st August 2008 02:38 AM
Pic Input Leads richard.c Micro Controllers 0 19th January 2008 11:14 AM
Replacing Laptop Battery - Custom ScuzZ General Electronics Chat 10 2nd December 2007 08:05 AM
Replacing a Battery DirtyLude Electronic Projects Design/Ideas/Reviews 5 13th July 2005 01:55 PM
