| i was wondering if i could create a direct link between 2 computers using a phone line and 2 modems. is this possible? i need a hight distance, but not very high speed. 56Kb is enough. anyone can help? | |
| What you describe is not an easy thing to do. I am sure i have seen a three-wire system running from serial port to serial port. That might suit you better, believe me it would be easier to run a couple of extra wires than to get modems to do it. (unless the distance is a very long way) I will try to find the info on a three-wire system for you. Regards, John | |
| i found this page, http://home.earthlink.net/~mrob/pub/rs-232.html about half way down you should find a section called null-modem. it describes the three wire serial port to serial port connection, and includes a sort of drawing for the no handshake type wiring, and the psuedo handshake type wiring. I feel there are many such pages on the net, have a look around. Regards, John | |
| If you're not trying to do this for the heck of it, an easier way is to use a null-modem connection. This site has a step-by-step on how to do it: http://www.weeno.com/art/0599/66.html
__________________ If this is not what you expected, please alter your expectations. | |
| well if u have 2 computers, 2 modems in each, 2 phone lines and a telephone exchange u can use telnet to connect from one computer to the other. in that way u can transfer files from one computer to the other. now if dont have the 2 phone lines and the telephone exchange then u should use the null modem technique. ill recommend using the null modem technique because there is no telephone exchange between. that means that the data will transfer fastly and the connection will not add up to your monthly telephone bill | |
| Here's one on the null modem cabling http://www.loop-back.com/null-mod.html There wasn't a length specified ,so that may be an issue....
__________________ gerty | |
| thanks for the info. it seems i have found what i needed. | |
