| hello! my sound card(actually integrated on the main board) has quite high noise. my speakers have noise cancelling circuit....but the headphones and wireless headphones...don't. so is there a solution so that i can reduce the noise? it would be good if the circuit doesn't need external power suply. i searched the net, but only found noise cancelling headphones. can any onehelp? thanks! | |
| Hi, what You need is called a 'noise gate'. It is used to mute a signal that is below an adjustable threshold. I don't know how to make one, but 'noise gate' may help You with further search. regards joachim | |
| hm, i am not sure that is what i want. the idea is that if i connect the headphones directly to the computer i hear a noise. the noise doesn't dissappear when the music plays or something else. i can't hear the same noise in my speakers, because they say that they have noise cancelling circuit. so...i want to build something similar for my headphones..... | |
| nope, i don't think so. how much can 1.5 meters of wire pick up? they are not active headphones. just simple 32 ohm headphones. so what do you think i should do? | |
| a lot of PC speakers have a headphone socket at the back. If you try them there, you could see if the noise is still there. or maybe you could try the headphone socket on the front of the CD player, but that limits you to CDs .... although it should sound clean. | |
| Your speakers have a noise-cancelling circuit? What did they do, leave out the tweeters? Try connecting the headphones in series with 180 ohms resistors, for each channel, like stereo amps do, instead of your speaker connections. | |
| hm.... well, i used reistors for headphones, but they were 160 ohm. don't think it is much difference. anyway...thanks for the advice... i'll see what i can do... | |
