Old 7th May 2009, 03:04 PM   #1
Default Low-voltage-drop current splitter?
I have a 0.25A@14V solar panel that I want to use to float charge two 12V flooded lead-acid deep-cycle batteries (boat). I would like to use a current-splitter to feed the two batteries so that if either battery were to develop a shorted cell, the other battery still gets half the available solar current.
I have used a "battery isolator" consisting of two diodes connected common anode, with the two cathodes connected to the positive pole of the two batteries, respectively. However, that just means that one battery can hog all the available current. In the event the battery goes bad, it hogs all the current and the other (good) battery gets none.
The current splitter circuit should have less than 1V drop between the solar panel input and the positive pole of the battery it is connected to.
MikeMl is offline
Old 7th May 2009, 03:21 PM   #2
You're going to need to monitor the current in and out to both batteries to be able to split it effectively. A duel switcher which limits Iout for each battery to be Iin/2.
I've been pondering how hard it would be to setup a charge system that charges each battery on a bank individually, and this is the basis of it. Would like to hear other ideas here too.
smanches is offline
Old 7th May 2009, 04:46 PM   #3
If you have a variable voltage input source the simplest way I can think of is the standard LM317 voltage regulator set up in constant current mode.
Once its set right each regulator will always give its load the same charging current regardless of if the input voltage goes high or the battery voltage drops low.
the attached spec sheet shows how you can set it up.
File Type: pdf LM317t Adjustable voltage regulator..pdf (732.6 KB, 32 views)
"Issue a general safety warning. Then look the other way and allow stupidity the chance to eliminate itself." -- tcmtech
"Those who can, Will. Those who can't, will achieve positions of power over those who can and then promptly stop them." -- tcmtech
"Your impossibility may just be my day to day routine." -- tcmtech
tcmtech is online now
Old 7th May 2009, 04:56 PM   #4
The problem with a LM317 limiter is that is requires a 1.2V drop before it starts limiting. You may want one that limits at a lower voltage.
You also could use a fold-back type limiter that would actually reduce the current limit if the battery voltage drops significantly below the charging voltage. A Google of "current limit circuit" will generate numerous hits.
Carl
Curmudgeon Elektroniker
crutschow is offline
Old 7th May 2009, 05:13 PM   #5
And that's just the voltage across the sense resistor. The total headroom required is closer to 3V.
Ron
Roff is offline
Old 7th May 2009, 05:32 PM   #6
How much current will your solar panel provide?
Ron
Roff is offline
Old 7th May 2009, 06:36 PM   #7
Open Circuit, 19V
0.25A@14V.
0.5A into a short.
MikeMl is offline
Old 7th May 2009, 09:22 PM   #8
How about this: Multiplex the solar cell with a 50% duty cycle, low frequency (e.g., 1Hz) multivibrator, driving two P-channel (or N-channel, if it is convenient to switch the low sides of the batteries) to switch between batteries. I don't think you would need any diodes for isolation, because the body diodes do that for you, and the intrinsic diode in the solar cell would prevent it from draining the batteries during darkness (I think ).
With a voltage monitor and a timer, you could probably isolate a bad battery and stop the multi, diverting all the current to the good battery until you replace the bad one. This sounds like a job best done using a microcontroller.
Ron
Roff is offline
Old 7th May 2009, 10:20 PM   #9
The solar cell diode polarity, when generating current, is positive at the anode (that's why a single solar cell has such a low voltage). Thus, when dark, the battery will be seeing a series of forward biased diodes. This may cause a small current drain from the battery, depending upon the number of solar cells in series. I believe some solar cells have a forward biased diode in series with the output to prevent this drain.
Carl
Old 7th May 2009, 10:22 PM   #10
You're right. My bad. A Schottky diode in series with the solar cell is probably required.
Ron
Roff is offline
Old 8th May 2009, 10:14 AM   #11
How about this: Multiplex the solar cell with a 50% duty cycle, low frequency (e.g., 1Hz) multivibrator, driving two P-channel (or N-channel, if it is convenient to switch the low sides of the batteries) to switch between batteries. ...
Clever! Much easier and no loss of power due to proper current sensing. And the current pulses should have some anti-sulphating effects which seems useful given the OP's fear of a battery fail problem.
Only needs a couple of pfets and a logic chip which can do both 50:50 oscillator and inverter/driver?
Mr RB is offline
Old 12th May 2009, 03:54 PM   #12
MikeMI, did you ever get this problem solved?
Ron
Roff is offline
battery, charging, current-splitter
Wind turbine voltage splitter verytricky Electronic Projects Design/Ideas/Reviews 26 5th August 2009 05:00 AM
Voltage Splitter? Question? average_male General Electronics Chat 10 22nd March 2009 01:29 AM
current drop at lm317 const current source kermit Electronic Projects Design/Ideas/Reviews 9 31st October 2008 04:36 PM
Read current (voltage drop across resistor) in two directions Odysseas Micro Controllers 22 18th October 2007 05:24 AM
Typical IR LED; what is the voltage drop & max current? William At MyBlueRoom General Electronics Chat 4 20th April 2006 12:51 PM
