+ Reply to Thread
Results 1 to 2 of 2
Thread: Power bootstrap direct from mains without transformer...
  1. #1
    smanches Excellent smanches Excellent smanches Excellent smanches Excellent smanches Excellent
    Join Date
    Mar 2009
    Location
    Oregon, USA
    Posts
    886
    Default Power bootstrap direct from mains without transformer...
    Other than not-being isolated, and hence dangerous, any suggestions on how to do this? I have a couple of ideas now, but have no idea if there might be standard ways of doing this. The issue is how to initially supply power to the control circuits in a power supply before it can start regulating it's own power.
    The first diagram uses a zener for bulk regulation, then a linear for fine tuning it. The problem with this approach is current is limited to the power rating of R1, which even at 33mA is already in the 5W range.
    The second diagram is a double FET regulator which outputs twice the gate voltage threshold at the output. It plays off the turn-on voltage of the FETS to keep the voltage regulated. It has the advantage of regulating much larger loads than the zener way, but suffers from instability if you start pulling too much current (at least according to LTSpice.)
    Any other ideas on how to do this? Or thoughts on my two ideas?
  2. #2
    Join Date
    Nov 2003
    Location
    Derbyshire, UK
    Posts
    29,788
    SMPSU's commonly do this, usually it's done via a high value resistor that charges a capacitor, the capacitor charges up and eventually a threshold voltage is reached, and the supply bursts into life. The capacitor has to store enough energy to keep the PSU running until it can be charged normally from the PSU output itself, normally via it's own winding.
+ Reply to Thread
  1. Running LEDs from mains power
    By samuel2801 in forum General Electronics Chat
    Latest: 15th March 2009, 07:25 PM
  2. 230-250v Mains power supply problem
    By Xpongo in forum Electronic Projects Design/Ideas/Reviews
    Latest: 10th April 2008, 10:27 PM
  3. CPU Power Supply Failure - Mains Trip
    By Electrix in forum General Electronics Chat
    Latest: 29th December 2007, 02:53 PM
  4. How to source a mains power electric motor, for a ball mill?
    By bitem2k in forum General Electronics Chat
    Latest: 5th August 2007, 07:47 AM
  5. Internet over mains power lines!!!
    By pike in forum General Electronics Chat
    Latest: 8th March 2004, 03:12 PM
Tags for this Thread
