Old 6th May 2009, 04:36 PM   #1
Default seven segment help
i don't know what resistors or voltage to use with this seven segment
::Compre Componentes Eletrônicos Baratos no www.Soldafria.com.br
no details is provided with it and i can't find any data sheet
can anyone help me find it?
on the display written
pa6 wlg and d23012a/b(e)
jokira247 is offline
Old 6th May 2009, 04:54 PM   #2
I would try adding a resistor (say 500Ω) in series with one of the segments and slowly increase the voltage until you get the desired brightness. Then measure the voltage across the resistor and calculate the current (or connect an ammeter in series with the resistor to find the current). I expect it will be somewhere around 10-20mA. From that you can calculate the required resistor value for the voltage supply you have.
If you go too high in current the brightness will seem to stop increasing with current. At that point you would be overdriving the LED.
Carl
Curmudgeon Elektroniker
crutschow is offline
Old 1st September 2009, 03:40 PM   #3
Hi!
Maybe this info is of no use since it's a long time question was raised but I've bought same 7 seg displays on ebay and here are some info
Common Cathode
Size: 2.3'' (69.70mm*47.80mm*12mm)
Forward Voltage: 7.5V
Forward Current: 5-10mA
hakha4 is offline
segment
7-segment to BCD ajmoreno Electronic Projects Design/Ideas/Reviews 1 16th March 2009 06:53 PM
BCD to 7-Segment bunghole Electronic Projects Design/Ideas/Reviews 0 9th December 2008 06:45 AM
Seven Segment shahtejasm Micro Controllers 1 6th May 2008 08:34 AM
help!!! nor=bcd to 7-segment butiki Electronic Projects Design/Ideas/Reviews 0 1st March 2006 09:40 AM
7 segment coba Micro Controllers 1 6th October 2003 05:53 PM
