+ Reply to Thread
Results 1 to 6 of 6
Thread: Wiring LEDS for car lights. Need assistance.
  1. #1
    Blis Newbie
    Join Date
    May 2009
    Posts
    3
    Default Wiring LEDS for car lights. Need assistance.
    Alright, so I made a custom set of the BMW Angel Eye lights for my sports car, and am now trying to wire them properly. The setup that I'm trying to do, is so that I can turn on the inner and outer rings separately, but then also turn them both on simultaneously. I'm hoping to do this without wiring a second switch, but not fully sure that it's possible. Below is a picture of the setup.
    Any help is greatly appreciated!
    Thanks!
    Greg
  2. #2
    MikeMl Excellent MikeMl Excellent MikeMl Excellent MikeMl Excellent MikeMl Excellent MikeMl Excellent MikeMl Excellent
    Join Date
    Mar 2009
    Location
    Utah
    Posts
    2,866
    The solution has to do with what kind of switch you can obtain. You basically need a four detent switch which could be wired to provide: Nothing, Inner, Outer, Inner & Outer. I have never seen an automotive style pull-switch with four detents. A three detent switch would could be wired to provide: Nothing, One, Both; where One could be either Inner or Outer.
    How much current do the lamps draw?
  3. #3
    Blis Newbie
    Join Date
    May 2009
    Posts
    3
    It's not lamps. LED's. High output. 960mlm intensity, 525nm wavelength, 20mA current, 3.5v supply. Those are attached to 470ohm resistors.
  4. #4
    Join Date
    Mar 2009
    Location
    Utah
    Posts
    2,866
    So how many LEDs are you switching?
    Any insight on the mechanical configuration of the switch?
  5. #5
    Blis Newbie
    Join Date
    May 2009
    Posts
    3
    each ring has 2 led's, so each line will have 2 leds and 2 resistors attached to it. I'm curious as to what type of a switch I need so I can set it up for Nothing, Outer lights, Inner lights, Both lights.
  6. #6
    Sceadwian Excellent Sceadwian Excellent Sceadwian Excellent Sceadwian Excellent Sceadwian Excellent Sceadwian Excellent Sceadwian Excellent
    Join Date
    Oct 2006
    Location
    Rochester, NY U.S.
    Posts
    9,826
    Blog Entries
    1
    If you do two LED's in series you can use a small current limit resistor disipating less heat and generally wasting less power. At 12 V DC you'll be burning 300mw's in the resistors. If I'm not mistake the resistor value for two 3.5 LED in series at ~20ma is 160ohms and it would only dissipate 100mw's
    straight answer, har har."
+ Reply to Thread
  1. Need assistance pushing more current to LEDs
    By Team PSU in forum Electronic Projects Design/Ideas/Reviews
    Latest: 21st April 2009, 04:30 PM
  2. Help - Simulating runway lights with LEDs
    By foxenergy in forum Electronic Projects Design/Ideas/Reviews
    Latest: 15th April 2009, 01:31 AM
  3. LED christmas lights wiring config ?
    By things in forum Electronic Projects Design/Ideas/Reviews
    Latest: 19th December 2008, 12:45 AM
  4. Assistance in wiring a simple circuit?
    Latest: 20th September 2008, 02:34 AM
  5. Converting Christmas lights to LEDs
    By holabr in forum General Electronics Chat
    Latest: 15th December 2007, 06:21 PM
Tags for this Thread
