+ Reply to Thread
Results 1 to 7 of 7
Thread: Signal and Digital Timer Issue
  1. #1
    tbass2k Newbie
    Join Date
    Apr 2009
    Posts
    3
    Default Signal and Digital Timer Issue
    I am trying to clean up a signal for timing purposes, I am switching a motor in a device and timing the switch in milliseconds with a digital timer. The timer is only timing the first pulse on the output signal from the motor which is only around 35-45 ms, the actual/entire switch time should be between 200-400 ms (I think). I believe there is some bouncing from the motor switching positions giving me this funky signal. Will an edge triggered flip flop get me closer to the correct signal/time? I have attached an image in PDF of what I'm getting and what I need. Any help is appreciated.
  2. #2
    MikeMl Excellent MikeMl Excellent MikeMl Excellent MikeMl Excellent MikeMl Excellent MikeMl Excellent MikeMl Excellent
    Join Date
    Mar 2009
    Location
    Utah
    Posts
    2,864
    Should the trailing edge of "Needed" be coincident with the trailing edge of "Current"?
    What is the min/max time from rising edge of "Current" to the trailing edge of "Current"?
    Is the noise pulse much narrower then either the initial pulse or the final pulse?
    Toggling an edge-triggered flip-flop wont work as the only fix because it will toggle on all three rising edges, the initial pulse, the noise pulse and the final pulse. A retriggerable one-shot with a period of about one-third of the total time you are expecting might help, because it will stay high for the duration.
  3. #3
    tbass2k Newbie
    Join Date
    Apr 2009
    Posts
    3
    Well, I would like the trailing edge of the 'needed' to match up as closely as possible with the trailing edge of 'current.'
    There is no min time for rising to trailing edge of current, but 40ms is obviously too short of a switch time for the mechanical device I am working with, which is the reason I am trying to get a time < 500ms (max time), which more closely correlates with the 'signal needed' waveform.
    The noise pulse, based on the scope, appears to be much narrower than initial or final pulse...the waveform I attached closely resembles what I am seeing on the scope. I believe my timer is timing the first pulse only (obviously) when I need it to time the rising edge of first pulse to falling edge of the last pulse (or as close as I can get to that).
    So based on this and the previous info, you still think a retriggerable one shot might work?
    Thanks again for the feedback.
  4. #4
    Join Date
    Mar 2009
    Location
    Utah
    Posts
    2,864
    Try a positive-edge re-triggerable one-shot with a period slightly shorter than the third pulse in your diagram. Hopefully, that will bridge across the gaps in "current".
    Rather than timing the signal directly, I would use a digital scope to capture the actual waveform. You can determine the relevant timing after the fact by inspection. Any one-shot solution may work for a time, but it is unlikely to work for all potential conditions.
  5. #5
    tbass2k Newbie
    Join Date
    Apr 2009
    Posts
    3
    Thanks for the fast reply, I was told by another engineer that the 54/74ls123 retriggerable one-shots are some of the most unreliable chips you can use and most engineers don't use them, as they may trigger with a +/- 3 degree change in temperature. At any rate, is there no other solution to clock on the first rising edge and final falling edge?
  6. #6
    Join Date
    Mar 2009
    Location
    Utah
    Posts
    2,864
    Not if you dont know for sure how many rising edges there are going to be.
    The engineers who complain about '123s don't know how to use them, or they try to use them to solve your kind of problem
    In your case, any fix using a one-shot, or counting edges will only work if the noise pattern happens the same way every time.
  7. #7
    DavidCary Newbie
    Join Date
    Jun 2009
    Location
    Tulsa Oklahoma
    Posts
    2
    PIClist: Debounce Switch Inputs links to an excellent article on debouncing by Jack G. Ganssle.
    Didn't we already talk about this on another thread?
    switch debouncing problem
+ Reply to Thread
  1. digital signal/ digital technic
    By tintincute in forum General Electronics Chat
    Latest: 22nd November 2009, 07:35 PM
  2. digital signal processing
    By naik_mc in forum Electronic Projects Design/Ideas/Reviews
    Latest: 2nd September 2008, 05:40 AM
  3. AVR: PWM for convert a digital signal to analoge!
    By kasser in forum Micro Controllers
    Latest: 12th July 2007, 02:03 PM
  4. New Digital Signal Processing DSP forum
    By dora in forum Micro Controllers
    Latest: 16th November 2004, 11:07 AM
  5. Digital signal processors (DSP)
    By dkjean_brian in forum General Electronics Chat
    Latest: 6th October 2003, 04:48 AM
Tags for this Thread
