+ Reply to Thread
Results 1 to 4 of 4
Thread: Low frequency F:V converter
  1. #1
    BigM Newbie
    Join Date
    May 2004
    Location
    Christchurch, New Zealand
    Posts
    2
    Default Low frequency F:V converter
    I have built the PPL frequency to voltage converter using the ideas on AN-210 (from National.com), but I need a quick, stable converter that will operate between 50-250hz, and I cannot get these circuits to run down that slow. Does anyone have an idea how I can get a f/v converter down to 50hz? The input signal changes from 50-250hz over about 10seconds
    ( ignition pulse from 2 stroke motor) and I am sampling the voltage at 50 times per second.
  2. #2
    Russlk Newbie
    Join Date
    Nov 2003
    Location
    New Hampsire, USA
    Posts
    2,457
    Check out the LM2917 or AD650 frequency to voltage ICs. They work down to 0 frequency but the ripple gets high if you want fast response.
  3. #3
    Roff Excellent Roff Excellent Roff Excellent Roff Excellent Roff Excellent Roff Excellent Roff Excellent Roff Excellent Roff Excellent Roff Excellent
    Join Date
    May 2003
    Location
    Idaho, USA
    Posts
    6,723
    I'm posting a block diagram below. I haven't built this, or even simulated it, but it should work. The principle is:
    1. Create a voltage that is proportional to period (1/F).
    2. Pass that voltage through a reciprocal (1/V) circuit.
    It should be very fast, with no ripple. It does depend on a clean input, i.e., no spurious pulses and low jitter, because, in contrast to most F-V converters, it has no filtering.
    I believe the AD633 datasheet has info on how to make an analog divider. If you need more help, I will try as time allows.
  4. #4
    BigM Newbie
    Join Date
    May 2004
    Location
    Posts
    2
    I've tried the LM2917.. it won't cope with a changing input frequency, and has high ripple. The ppl circuit copes well, but even though the app note suggests increasing capacitor size, it slows the settling time down too much to sample quickly.....
+ Reply to Thread
Tags for this Thread
