OK so I am using MOSFETs to switch on and off short pieces of ni-chrome wire. I am using a 5A 12Vdc power supply. I have one end of resistance wire (about .6ohm) connected to +12 the other end connected to drain. The source is then grounded. I will eventually be using a 12v decoder (VDD will be the same 12v supply) but for now I am just connecting the gate to 12v via a 10k resistor and then grounding the gate to shut it off. This all works fine and dandy with a indicator light or in a simulation but once I hook up the resistance wire the mosfet gets hotter than the wire!! Whats wrong!!!
Also, I'm having a hard time understanding the equation for this but what is the opinion on the size of smoothing cap(s) for the above mention supply. 12v 5A
Thanks!
Sort of like insider trading info, only you have insider design info!
