Use a PIC to do it, or any other micro-controller - you need to intrface the DAC in someway anyhow, presumably it doesn't just take RS232?.
Me and a friend are designing a lasershow controller consisting of a FTDI USB-serial chip and a DAC from Analog, but because the output of a PC is not always steady, we need somehting to buffer the serial data until a new chunk of data is received. Any idea's?
Cheers,
Dan![]()
The 3 laws of science....
1. If it smells bad, It's chemistry.
2. If it's mushy, It's biology.
3. If it doesn't work, It's physics.
www.laserchat.org IRC chat for laser and electronic related stuff.
Hmm OK, Thanks.. We are intending on using this DAC chip: AD5668 | Octal, 16-Bit D/A Converter with 5 ppm/°C On-Chip Reference in 16-Lead TSSOP | D/A Converters | Digital to Analog Converters | Analog Devices
-Dan
Hmm, why is my Reputation bad? I haven't done anything wrong have I?
hahaha OK
Well, essentially, we have the FTDI drivers here for a premade DAC that uses a FTDI chip too, so essentially all we need to do, is interface PC ->FTDI USB - Serial -> Buffer -> DAC and then amp 2 of the DAC outputs to +/-5V differential, and the other channels to just 5-0v, then the rest is just software. Sounds about right, am I missing anything?
What speed will the serial be running? Feeding what I assume is a stereo DAC at good quality is a lot of data and will define how you can solve the problem.
| Similar Threads | ||||
| Thread | Starter | Forum | Replies | Last Post |
| HELP! I need idea's for my thesis! | Moisff | Electronic Projects Design/Ideas/Reviews | 4 | 1st October 2008, 01:12 AM |
| Idea's for Capacitors | weegee | General Electronics Chat | 12 | 4th October 2006, 08:49 PM |
| Need idea's for IR reciever | Roboticinfo | Robotics & Mechatronics | 16 | 17th April 2005, 11:33 AM |
| Need idea's for IR reciever | Roboticinfo | Electronic Projects Design/Ideas/Reviews | 2 | 16th April 2005, 01:51 AM |
| Lazer Alarm, Any idea's? | SchutzhundK94 | Electronic Projects Design/Ideas/Reviews | 6 | 16th September 2004, 10:55 PM |
