| Can anyone out there help? I need to insert a device between a satellite dish and receiver in order to set a delay between received signal and output to screens. This is for artistic display to screens where there is a variable delay from approx 15 seconds and max 120 seconds which can be controlled. I can buy on market DRV system which controls record/delay/send to screens but these only work on each selected channel being recorded or viewed. I need to have a buffer on the cable before the receiver so that I can control output on all channels signals being picked up by the dish LNB. Any cheap and easy ideas needed a s a p Regards to all wayneevanb | |
I can only suggest putting a harddrive recorder on the output of each satellite receiver. | ||
| you could use a high spec PC, with several tv-tuners in. Each could record any channel you wanted, and these recordings could be played back, using several different screens (you would need as many graphics cards as you would have tv tuners though). thinking about it, this would probably be alot more expensive than a hard disk, or DVD-Ram recorder, so prob a stupid idea, but anyway, its alternative for you to think about. Tim. | |
