| i have a problem, im representing a analog signal that im converting it to digital, then when i try to display on a 7 segment display with a 7448 bcd driver, a 10, i want it to turn to 0 and that in another display it gives me a 1, how can i do it? | |
| first of all i dont understand the subject. Quote:
regarding to your question. im sorry its hard to understand what u r asking. are u asking how to display 10?? for that u should have two BCD lines driving two displays. one will have the code for zero (0000) and the other will have the code for one (0001). i hope that helps | ||
| | (permalink) | ||
11011011 (binary) = 219 (decimal) = 0010 0001 1001 (bcd). That requires a decoder. | |||
| Isn't that called semantics? I thought you were implying that no logic transformation (encoding, decoding, transmogrification, whatever) was required to get from binary to BCD. | |
| | (permalink) | ||
i think we should not argue on semantics and rather try to answer his question. i told that im sorry i dont understand the question. but i did try to answer the question from what i understood. | |||
| One way to do it would be to similtanously clock BCD and binary counters. When the binary numbers are equal, you can read the BCD counter.
| | (permalink) | |||
The binary to BCD converters I have seen require a microcontroller or microprocessor. There was a TTL part, 74185, but it seems to have been discontinued. If you had a multi-digit BCD counter, and you converted the output to binary, would that be called an encoder or a decoder? I think perhaps "converter" is a better term, no matter which way you are going. | ||||
| | (permalink) | |||
| I think one of the biggest problems in this thread is the use of 'BCD', I'm not exactly sure what is wanted - but I presume it's to display a binary number as decimal, so if it's an 8 bit binary number you want the display to go from 0-255. If this is so, it's nothing to do with BCD at all, BCD isn't a method of displaying a binary number, it's a way of doing decimal maths in a binary system. With BCD your 8 bit number could only go from 0-99 in decimal, or 0000000-10011001 in binary, many processors have BCD maths capability. Remember, BCD means 'Binary Coded Decimal'. Perhaps jacuinde would like to give more details of exactly what he's trying to do?, in particular how many bits are being used, and how he wants them displaying. | |
| Nigel i think the biggest problem in this thread is that jacuinde is silent :lol: i think he isnt using any processor. he might just have BCD from discrete logic ICs. i think that he wants to display two digit numbers. and he is asking that how would the second digit be displayed. it could have been that he encoded binary into BCD and now he wants to display it on a two digit display. but all of that depends on jacuinde's reply | |
But why is your a/d converter giving you as 10 instead of a 0? Len | ||
| i have inputs in 4 bit binary ( from 0 to 15). i want to display my 4 bit binary inputs to 7 segment display which means i must have two 7 segment display. how can i convert my binary inputs to bcd in simplest way? can anyone give me explaination on how to make both of my 7 segment display the outputs of two digits ( from 00 to 15)? -thank you | |
| I think I know what jacuinde is asking because i have a similar question. Say that you have an 8 bit AD converter, and you want to display it's full range of base 10 values, that is 1 through 256. Is there a chip that will take this 8 bit number and decode it to a 3 digit display. I know that the 7448 (BCD-to-seven-segment decoder/driver) will take a 4 bit binary number and convert it to hexidecimal:0 through 9 and A through F (on a one digit display). Jacuinde wants to take a 4 bit number and display 0 through 15 (using a 2 digit display). Is there a decoder chip similar to the 7448 that will do this? | |
| One addendum. I just noted that jacuinde asked this question 4 years ago. Is anyone out there? | |
