+ Reply to Thread
Page 3 of 3
First 1 2 3
Results 31 to 43 of 43
Thread: Bicycle dynamo LED - adding a "super cap" to keep it lighted ( after stopping )
  1. #31
    Sceadwian Excellent Sceadwian Excellent Sceadwian Excellent Sceadwian Excellent Sceadwian Excellent Sceadwian Excellent Sceadwian Excellent
    Join Date
    Oct 2006
    Location
    Rochester, NY U.S.
    Posts
    9,826
    Blog Entries
    1
    Super caps are expensive as well. 5V 1 Farrad caps will set you back 9 bucks. Damn nice though, I modified a cheap hand crank LED flash light to use a Powerstor one instead of a battery, charges in only a few seconds of some stiff cranking, ESR is pretty high on the one's I got (1.5 ohms at DC) but they make much better ones. I should have bought a lower ESR one myself but they were an impulse purchase, still have a couple kicking around.
    straight answer, har har."
  2. #32
    Dotnet Newbie
    Join Date
    Jul 2005
    Location
    South Devon, England
    Posts
    48
    Quote Originally Posted by Boncuk View Post
    I suggest to use an electric motor on your bicyle. That way you won't have to use any body power.
    Don't say that - he'll stick a dynamo on his bike (via a supercap) to feed the motor.!!!!!
    (I've discovered perpetual motion - cough cough)
    There will be so much metal on his bike he won't need lights because when a Hummer hits him at a traffic light - the Hummer will come of worse he! he!
    Serously - listen to people here (well the ones not PLEADING for help with their homework) there's ways of doing things..
    At the end of the day you want light - LOTS OF LIGHT you need to feed your LED, Lamps, Bulbs, Hallides, Plasma injectors whatever by batteries. I would strongly suggest you use the dynamo to 'top up',(ish) batteries - Lithium Ion. Work on a battery boost when you brake - but use batteries, worst case scenariou you take of at home and charge them.
    Matt
  3. #33
    Boncuk Excellent Boncuk Excellent Boncuk Excellent Boncuk Excellent Boncuk Excellent Boncuk Excellent Boncuk Excellent
    Join Date
    Nov 2007
    Location
    Phetchabun,Thailand
    Posts
    3,460
    Quote Originally Posted by Dotnet View Post
    Matt
    Hi Matt,
    I've absolutely no problems generating electric power pedal driven. Grandma sits on a byce (without wheels to save weight) 12 hours per day and generates the necessary electric power the kids require to watch their fancy TV-shows.
    As soon as Grandma falls off the byce unconscious there is no electric power for the TV and the kids go to sleep.
    Don't be worried about Granny. The entire area around the byce is well wadded so she won't get hurt.
    Granny might be considered a "perpetuum mobile" since she generates 1.2KW daily with little food.
    Boncuk
  4. #34
    tcmtech Excellent tcmtech Excellent tcmtech Excellent tcmtech Excellent tcmtech Excellent tcmtech Excellent tcmtech Excellent tcmtech Excellent tcmtech Excellent
    Join Date
    Feb 2009
    Location
    Sawyer, North Dakota, USA
    Posts
    3,286
    Blog Entries
    2
    Those SuperCaps are not manufactured in China, but in Germany! Never heard about German precision work?
    Yea I've heard of precision German work. That Hindenburg worked real well!
    So did the WWII tanks that got their butts handed to them by the crappy American tanks we admit that we half assed built!
    I am also starting to see that the few hundered dollar build price I mentioned is not looking to be that far off now!
    Amost makes a guy wonder if I didnt do some practicality research relating to ultra caps as power sources at some time.
    Granny power huh? Why not make the kids do the work for their shows!
    Then they will go to bed sooner!
    "When in doubt, LIGHT IT ON FIRE AND SEE WHAT COLOR OF SMOKE IT CAN MAKE!" -- tcmtech
  5. #35
    Join Date
    Mar 2004
    Location
    Canada, of course!
    Posts
    19,879
    Quote Originally Posted by tcmtech View Post
    Didn't you see the very fast British destroyer ships in the South American Falklands war? They were made of lightweight magnesium and caught on fire like a match. Maybe they were hydrogen powered too.
  6. #36
    Join Date
    Oct 2006
    Location
    Rochester, NY U.S.
    Posts
    9,826
    Blog Entries
    1
    I didn't think solid magnesium would burn very well?
  7. #37
    Join Date
    Feb 2009
    Location
    Posts
    3,286
    Blog Entries
    2
    Believe me when you get it hot enough in one spot thick magnesium will burn very well! And then it will just keep going!
    I have had a few locals bring me "aluminum" parts for vehicles and farm equipment over the years in order to get them welded.
    About ten seconds into the weld is when it becomes clear that its magnesium and not aluminum!
    I just keep the welding helmet on and watch it burn!
  8. #38
    Join Date
    Mar 2004
    Location
    Canada, of course!
    Posts
    19,879
    When the Argentine missles hit the British magnesium destroyer ships then the ships burned with a very hot white flame.
  9. #39
    Join Date
    Oct 2006
    Location
    Rochester, NY U.S.
    Posts
    9,826
    Blog Entries
    1
    That's about all you can do with magnesium, it doesn't like to be put out.
  10. #40
    Join Date
    Feb 2009
    Location
    Posts
    3,286
    Blog Entries
    2
    I occasionally do some magnesium welding but when I do it I absolutely go nuts with the shielding gas flow! And after I stop welding I keep the shielding gas flow on it until it cools down.
    Its when I dont know its magnesium and just assume its an aluminum alloy of some type that I jet the uncontrolled burn going! By then its usually to late to run over and turn the shielding gas flow up.
  11. #41
    Join Date
    Oct 2006
    Location
    Rochester, NY U.S.
    Posts
    9,826
    Blog Entries
    1
    Is it even possible to put Magnesium out once's it's going? It's self oxidizing right?
  12. #42
    Join Date
    Nov 2007
    Location
    Phetchabun,Thailand
    Posts
    3,460
    Quote Originally Posted by Sceadwian View Post
    It really does. BMW-engines consist of an aluminum-magnesium alloy. Once the engince catches fire (engine overheat or spilled fuel by a broken fuel pipe)there is almost no way to fight it.
    The radial engines of the Convair420/440 consisted of aluminum-magnesium, too. With an engine fire (causing dense white smoke) you better prepare for a parachute landing.
    Fire extinguishers will fail fighting a magnesium fire and water makes the flames higher.
    The only way of extinguishing the fire is letting it starve by lack of oxygen.
    Boncuk
  13. #43
    Join Date
    Oct 2006
    Location
    Rochester, NY U.S.
    Posts
    9,826
    Blog Entries
    1
    Well, thing of it this way, if any part of the engine survives the crash you can use a sharp knife to scrap a block of what's left of the engine to make a fire starter =P Just add a little bit of iron oxide and you can't even starve it for oxygen =)
+ Reply to Thread
Page 3 of 3
First 1 2 3
  1. "mplab" + "pic assembly languag"e + "c++" = i need help !!!
    By kira_kame in forum Micro Controllers
    Latest: 6th April 2009, 06:14 PM
  2. Replies: 6
    Latest: 12th September 2008, 05:31 PM
  3. Laptops "O" and "P" buttons not working.
    By pkshima in forum Chit-Chat
    Latest: 18th August 2008, 11:31 PM
  4. Changing "dark on" switch to "light on"
    By NewUser in forum General Electronics Chat
    Latest: 15th September 2007, 03:30 AM
Tags for this Thread
