+ Reply to Thread
Page 1 of 2
1 2 Last
Results 1 to 15 of 18
Thread: Single board computer using 8088 pcb
  1. #1
    aflatoon1989 Newbie
    Join Date
    Sep 2007
    Posts
    17
    Exclamation Single board computer using 8086 pcb
    greetings mates ...im new to pcb making and im designing sbc in diptrace but having problems in routing data lines and address lines of 8086 of same size can anyone guide me how to do tht...or there is any other software more suitable for this job....plz reply..i have attached schematic which i designed in diptrace
  2. #2
    Help us help you blueroomelectronics Excellent blueroomelectronics Excellent blueroomelectronics Excellent blueroomelectronics Excellent blueroomelectronics Excellent blueroomelectronics Excellent blueroomelectronics Excellent blueroomelectronics Excellent blueroomelectronics Excellent blueroomelectronics Excellent
    Join Date
    Jan 2007
    Location
    Toronto, Canada
    Posts
    10,711
    Blog Entries
    5
    That'll be a tough PCB to route. How many layers are you using?
    Bill
    Smart Kits build Smart People
  3. #3
    aflatoon1989 Newbie
    Join Date
    Sep 2007
    Posts
    17
    single layer ya thts the tough task
  4. #4
    Join Date
    Jan 2007
    Location
    Toronto, Canada
    Posts
    10,711
    Blog Entries
    5
    It would be tough with two layers. Why not just wire wrap it or find an old PC XT?
    Bill
  5. #5
    ericgibbs Excellent ericgibbs Excellent ericgibbs Excellent ericgibbs Excellent ericgibbs Excellent ericgibbs Excellent ericgibbs Excellent ericgibbs Excellent ericgibbs Excellent ericgibbs Excellent ericgibbs Excellent
    Join Date
    Jan 2007
    Location
    Hampshire. England.
    Posts
    10,849
    Blog Entries
    13
    Quote Originally Posted by aflatoon1989 View Post
    single layer, you must be joking, if yes, how many links...
    why must it be single layer.?
    Link to my Articles: http://www.electro-tech-online.com/a...icgibbs-55450/
  6. #6
    aflatoon1989 Newbie
    Join Date
    Sep 2007
    Posts
    17
    lolzz thts the good idea but cant do it .....coz my teacher give me this task and i have to do it...
  7. #7
    Join Date
    Jan 2007
    Location
    Toronto, Canada
    Posts
    10,711
    Blog Entries
    5
    Good luck.
    Bill
  8. #8
    Join Date
    Jan 2007
    Location
    Hampshire. England.
    Posts
    10,849
    Blog Entries
    13
    IMO the task is unfair and totally unrealistic.
    Surely there must a more useful project for you to study.
  9. #9
    aflatoon1989 Newbie
    Join Date
    Sep 2007
    Posts
    17
    im working on it its done only 25% ....lets see if its really impossible then i will convert it to double layer pcb.....
  10. #10
    Join Date
    Jan 2007
    Location
    Toronto, Canada
    Posts
    10,711
    Blog Entries
    5
    I remember a wire wrapped 8088 from the 8088 book.
    Bill
  11. #11
    ronsimpson Good ronsimpson Good ronsimpson Good
    Join Date
    Apr 2007
    Location
    Loveland, CO USA
    Posts
    711
    Aflatoon some advice.
    If you really understand how the circuit works you can make changes that help.
    On static RAM there is no reason to use A0, A1, A2,... You can mix up A0 and A6 and there is no problem. I change the sch to make the layout easy.
    On static RAM you can change D0--D7.
    On the PLACE16V8 you can move around any input to any input pin. Also the outputs can be moved to different pins. The part must be reprogrammed but that is a small problem.
    The 74LS573 and like parts. This is a 8 bit latch. Pins 2->19 is a latch. Pins 3->18 is a latch. You can exchange pin pairs 2,19 and 2,18.
    Do no do this unless you really know the circuit!
  12. #12
    Sceadwian Excellent Sceadwian Excellent Sceadwian Excellent Sceadwian Excellent Sceadwian Excellent Sceadwian Excellent Sceadwian Excellent
    Join Date
    Oct 2006
    Location
    Rochester, NY U.S.
    Posts
    9,826
    Blog Entries
    1
    You might be able to route it using a lot of headers and IDC cables. By no means an easy solution because you'd have to hand route the whole thing. But doing headers and cables eliminates a lot of routing problems. A lot of cheap single layer boards I see use judicious amounts of jumper wire. IDC cables on headers or just soldering ribbon cable directly to the PCB would work.
    straight answer, har har."
  13. #13
    mneary Excellent mneary Excellent mneary Excellent mneary Excellent mneary Excellent mneary Excellent mneary Excellent mneary Excellent mneary Excellent
    Join Date
    Feb 2007
    Location
    California USA
    Posts
    3,835
    If this is the entire circuit you are missing about 20 bypass capacitors.
  14. #14
    aflatoon1989 Newbie
    Join Date
    Sep 2007
    Posts
    17
    yup i divided it in 3 parts in is of i/o card ,ram,rom section,,and microprocessor section...lets see how far it can solve my prob....thanks for ur advice 'Sceadwian'
  15. #15
    cavelamb Newbie
    Join Date
    Sep 2009
    Posts
    2
    Default 8088 singleboard
    I'm coming in late, but I thought I'd share my 8088 SBC
    layout. It's an 8 Mhz XT clone 5" x 7.25 " two sided board.
    512K ram, 512K eprom, Interrupt controller, timer, 8251 serial port with MAX 232 level converter, 8255 parallel I/O,
    etc.
    It is hand routed.
+ Reply to Thread
Page 1 of 2
1 2 Last
  1. Mini Board Computer pickout help?
    By Krumlink in forum Micro Controllers
    Latest: 20th January 2008, 06:13 PM
  2. Looking for a good computer board
    By moody07747 in forum Chit-Chat
    Latest: 29th December 2006, 09:23 PM
  3. looking for a computer message board...
    Latest: 22nd October 2006, 07:00 AM
  4. Single Board Computer vs System in Module
    By atang in forum General Electronics Chat
    Latest: 11th April 2006, 11:38 AM
  5. Single board computers built around PIC
    By vr in forum Micro Controllers
    Latest: 10th June 2005, 11:48 PM
Tags for this Thread
