there is a direct replacement that is better for the LM324 quad op-amp but i cannot remember what the the heck it is can anybody tell me?
TL084, MC33174 are the two that spring to mind, there are many more. It depends on the application so you need to give more information.
__________________ I do not answer private messages asking for help because no one else can: benefit from advice I may give or correct me if I'm wrong. Please ask on the open forum if you have a question and I'll be happy to help, if I know the answer. Last edited by Hero999; 14th April 2009 at 01:07 AM. | |
The LM324 is low power, works with a supply as low as 3V, has inputs that work at the negative supply voltage (0V when there is one supply), and has a bandwidth at max output voltage of only about 1kHz to 2kHz (its datasheet shows a graph of the bandwidth dropping as its output voltage increases but the graph stops at half the max output voltage. Its bandwidth is 5kHz at half its max output voltage and it has high crossover distortion. Its max allowed supply is only 32V. The MC33174 has exactly the same low power, also works with a supply as low as 3V, also has inputs that work at the negative supply voltage (0V when there is one supply), but has a bandwidth at max output voltage of 35kHz and has no crossover distortion. Its max supply voltage is 44V. The MC34074 has normal power, also works with a supply as low as 3V, also has inputs that work at the negative supply voltage (0V when there is one supply), but has a bandwidth at max output voltage of 100kHz and also has no crossover distortion. Its max supply voltage is also 44V.
| amp, quad |
| Quad 303 power amp problems | Thunderchild | Repairing Consumer Electronics | 4 | 16th March 2009 08:48 AM |
| quad comparator | Spikeneeds2no | General Electronics Chat | 1 | 29th November 2008 04:25 AM |
| Quad version of the 74LCX245 | UTMonkey | General Electronics Chat | 4 | 3rd June 2008 12:34 PM |
| TL084 quad op-amp help | coolrfid | Datasheet/Parts Requests | 12 | 10th May 2008 10:10 PM |
| Quad 404!!! | chiriac_marius | Electronic Projects Design/Ideas/Reviews | 2 | 9th October 2004 08:16 AM |
