+ Reply to Thread
Results 1 to 14 of 14
Thread: Require super tiny battery.
  1. #1
    bowser22 Newbie
    Join Date
    Apr 2009
    Posts
    46
    Cool Require super tiny battery.
    Looking for a battery or multiple batterys that will fit into a bic pen tube and still allow travel for wires. I require it to give me 3.3v at the same mah as rs232 standards. Its a project to build a super tiny self contained probe if youre wondering. Anways!
    Thanks alot
    ''Bowser
  2. #2
    4um Addict Mike2545 Excellent Mike2545 Excellent Mike2545 Excellent Mike2545 Excellent Mike2545 Excellent Mike2545 Excellent Mike2545 Excellent
    Join Date
    Jan 2009
    Location
    Toledo, Ohio
    Posts
    838
    Don't know what pen you are using exactly, but I have a regular pen here that measures .273 ID and the EverReady 364 cell is .267 dia.
    Mike 2545
  3. #3
    Sceadwian Excellent Sceadwian Excellent Sceadwian Excellent Sceadwian Excellent Sceadwian Excellent Sceadwian Excellent Sceadwian Excellent
    Join Date
    Oct 2006
    Location
    Rochester, NY U.S.
    Posts
    9,825
    Blog Entries
    1
    You're not going to find batteries that small that will meat your requirements. Batteries that small can barely put out any current, let alone the voltage and current requirements for RS232, at least not for more than about a minute.
    straight answer, har har."
  4. #4
    bowser22 Newbie
    Join Date
    Apr 2009
    Posts
    46
    i just thought maybe a few micro nimh batteries could pull it off
  5. #5
    Join Date
    Oct 2006
    Location
    Rochester, NY U.S.
    Posts
    9,825
    Blog Entries
    1
    The inside of a bic pen is pretty tiny, not much room in there for anything. What are the running current requirements for your circuit? and what kind of run time to do you need? Considering you're using RS232 for communication why can't you also connect a power cable? Or use the handshake lines to sneak a little bit of power?
  6. #6
    bowser22 Newbie
    Join Date
    Apr 2009
    Posts
    46
    its a probe for retreiving the key data from an xbox 360 drive and im trying to contain it all in one package, i may produce these units to make a little bit of cash.
    thats what im working on, see where the 5v comes from the molex? that should be 3.3v and im trying to supply that power without the use of an external power source or extra connectors.
  7. #7
    Join Date
    Oct 2006
    Location
    Rochester, NY U.S.
    Posts
    9,825
    Blog Entries
    1
    So what do you need a battery for?
  8. #8
    mneary Excellent mneary Excellent mneary Excellent mneary Excellent mneary Excellent mneary Excellent mneary Excellent mneary Excellent mneary Excellent
    Join Date
    Feb 2007
    Location
    California USA
    Posts
    3,813
    I have to assume you're talking about the current popular Bic Round Stik pen family, which has an inner diameter of about 6.5 mm. The smaller hearing aid batteries (520010, 520020) are 5.75 and 5.8 mm respectively.
  9. #9
    bowser22 Newbie
    Join Date
    Apr 2009
    Posts
    46
    so i dont have to connect it to molex or external power,,, but can rs supply that power needed?
  10. #10
    bowser22 Newbie
    Join Date
    Apr 2009
    Posts
    46
    can i stack hearing aid batteries into a cell or will it quickly be drained?do they make rechargeable hearing aid batteries?
  11. #11
    leftfield95 Newbie
    Join Date
    Aug 2008
    Location
    lincs, UK
    Posts
    7
    A BR435 will probably fit inside any pen sized case you could imagine, but they are expensive.
    You’d be better off powering it from the serial port or USB, since you are already connecting it to the computer.
  12. #12
    Leftyretro Excellent Leftyretro Excellent Leftyretro Excellent Leftyretro Excellent
    Join Date
    Mar 2007
    Location
    Hercules, California
    Posts
    1,420
    You will also have to have a means to wire a common reference (ground) between the X-box and the probe monitor (DB-9 pin 5) for this to work.
    Lefty
    Measurement changes behavior
  13. #13
    bowser22 Newbie
    Join Date
    Apr 2009
    Posts
    46
    what do you mean a common ground?like a ground from the db9 to the grnd on the drive?why doesnt this schem have a common ground
    ;colin
    ps...sometimes i sound very stupid
  14. #14
    Join Date
    Mar 2007
    Location
    Posts
    1,420
    Quote Originally Posted by bowser22 View Post
    ;colin
    "like a ground from the db9 to the grnd on the drive?"
    Yes, that is what is required.
    "why doesnt this schem have a common ground"
    I see a ground pin located in the picture of the board.
    Lefty
+ Reply to Thread
  1. Require help with bluetooth
    By SOCRATES9 in forum Electronic Projects Design/Ideas/Reviews
    Latest: 7th January 2010, 11:21 AM
  2. Require help
    By nitskulkarni in forum Electronic Projects Design/Ideas/Reviews
    Latest: 7th September 2008, 08:01 PM
  3. Require info on TFT-LCD with PIC
    By abicash in forum Micro Controllers
    Latest: 21st July 2008, 01:09 PM
  4. Super super noob question
    By hvgap in forum General Electronics Chat
    Latest: 13th January 2007, 11:12 PM
  5. Which PICs require VPP before VDD?
    By William At MyBlueRoom in forum Micro Controllers
    Latest: 25th August 2006, 03:16 AM
Tags for this Thread
