regulated DC power supply
12 Last »
  1. #1
    fluffy13 fluffy13 is offline
    hello... anyone who can help me design a regulated DC power supply that will supply 3, 5, 6, 7.5, 9 and 12?
  2. #2
    crutschow crutschow is offline
    How much current at each voltage?
    0
    Zapper
    Curmudgeon Elektroniker
    --Inside every little problem is a big problem trying to get out.--
  3. #3
    tcmtech tcmtech is offline
    Check out the specs sheets on a LM317 adjustable voltage regulator.
    Or any other adjustable type regular. There are switching types too that have higher operating efficiencies as well but doe take more parts and are harder to build.
    0
    "Only someone with something to hide has reason to fear open and honest communication."
    The scariest thing about where I work is that I am the good employee!
  4. #4
    microtexan microtexan is offline
    Regulated power supply
    At the top of this page is "link" to search this form. A search for "regulated power supply" produces over 100 results. A little work on your own goes a long way.
    0
  5. #5
    mneary mneary is offline
    See the LM317 data sheet. From there, it's mostly a mechanical design.
    All you have to do is design one power supply using an adjustable regulator and get it working. Then build five more to fit in the same box with different calculated outputs and you're done. It's up to you whether to share one transformer or use several. The biggest decision you'll have to make is whether you want all of the (-) terminals to be common, or not.
    0
  6. Thread Starter #6
    reply
    Quote Originally Posted by crutschow View Post
    uhm.. current- not specified.. we are just asked to come up with the given voltage output.
    0
  7. #7
    Ah! another class project! I should have guessed.
    0
  8. Thread Starter #8
    Quote Originally Posted by tcmtech View Post
    yah! class project.. haha.. we already have our circuit design. we also tried to build a power supply. we just don't know why 2 of the LEDs aren't working. and if we measure the voltage output at each, it remains constant. voltage output should change from 3 then 5 then etc...
    0
  9. Thread Starter #9
    do we really have to know the current at each voltage?
    0
  10. #10
    Only if you are actualy going to power something with it. Other wise its just theoretical.
    0
12 Last »
Help with my Regulated Power Supply Pls.. sv_clintrace999 Electronic Projects Design/Ideas/Reviews 23 25th February 2009, 07:01 AM
DC regulated power supply davidbball13 General Electronics Chat 20 28th July 2008, 12:58 AM
Help: Regulated Power Supply hardcore misery General Electronics Chat 41 14th November 2006, 07:50 AM
Regulated power supply eblc1388 General Electronics Chat 24 18th August 2006, 10:55 AM
Regulated DC power supply skyymanz Electronic Projects Design/Ideas/Reviews 16 16th July 2005, 10:00 AM
Page Time: 0.11430 seconds      Memory: 7,643 KB      Queries: 16      Templates: 0
