+ Reply to Thread
Results 1 to 4 of 4
Thread: ISD17240 voice recorder chip timing problem
  1. #1
    cincailo Newbie
    Join Date
    Dec 2008
    Posts
    16
    Default ISD17240 voice recorder chip timing problem
    Hello everyone! I'm using a PIC to control for the recording and playback of the voice recorder chip, ISD17240. But then facing a problem to synchronize both the chip. Since I'm using the SPI method where PIC is master while ISD17240 is slave so every MISO and MOSI need clock to send or receive data. My PIC has a crystal which generate clock pulse but it is much higher than the ISD17240 needed. Any suggestion in making the two chips have the same clock? Or actually it is not the crystal to give the clock pulse to both PIC and ISD17240 clock pin for receiving and transmitting data?
    Thanks.
  2. #2
    duffy Excellent duffy Excellent duffy Excellent duffy Excellent duffy Excellent duffy Excellent
    Join Date
    Dec 2008
    Location
    nortern 'sconsin
    Posts
    1,822
    It's not the crystal, there is a separate SPI clock pin (SCK) on the Pic chip for synchronous serial communications. Check un the USART section of the spec sheet, there are actually 4 pins for the SPI - SDI, SDO, SCK, and /SS.
  3. #3
    cincailo Newbie
    Join Date
    Dec 2008
    Posts
    16
    Yes, I know there are 4 pins for SPI. So want to know that SCK = Fosc/4 ? The Fosc is crystal? Is it I just need to change the SCK to a value that suit the slave?
  4. #4
    Join Date
    Dec 2008
    Location
    nortern 'sconsin
    Posts
    1,822
    One of the SSPCON registers allows you to select the frequency for the SPI port clock signal. You can typically divide Fosc by 4, 16, and 64. If that is still too fast, you have the option to use one of the timers as the frequency generator for SCK.
    The spec sheet is your friend, read the spec sheet.
+ Reply to Thread
  1. Voice recorder using ADC and microcontroller
    By 4electros in forum General Electronics Chat
    Latest: 19th February 2010, 04:05 AM
  2. Voice recorder...
    By Rescue1 in forum Electronic Projects Design/Ideas/Reviews
    Latest: 5th April 2009, 05:35 AM
  3. ISD voice recorder chip in Malaysia
    By cincailo in forum Datasheet/Parts Requests
    Latest: 24th December 2008, 10:09 AM
  4. digital voice recorder
    By piyush_it1 in forum General Electronics Chat
    Latest: 28th March 2006, 10:20 AM
  5. digital voice recorder
    By piyush_it1 in forum Electronic Projects Design/Ideas/Reviews
    Latest: 13th March 2006, 08:51 AM
Tags for this Thread
