+ Reply to Thread
Results 1 to 7 of 7
Thread: Another touch switch question
  1. #1
    twist2b Newbie
    Join Date
    Oct 2008
    Posts
    30
    Default Another touch switch question
    So I see complicated switches, and easy cheesy switches :P
    Simple Toggle Touch Switch Using Two Inverter Gates | Free Circuit Diagram
    SO I thought this was genius for simplicity.
    Though wondering how well it would work.
    What I am looking for:
    I need an ON/OFF for each time you touch it. Touch let go... on... touch let go... off. I have seen way to many schematics that just turn on WHILE your touching it.
    My project is connected to 120VAC so I am looking for continuous red LED while its off. Then when it turns on the red LED turns off.
    My HOPE was to be able to use a clear plastic with LEd behind it and the plastic IS the material you touch.
    Looking around google shows flip-flops as a popular option....
    So many freakin ways to do it, its so hard to decide the best path to take, so just asking for some advice.
    Thanks.
  2. #2
    Sceadwian Excellent Sceadwian Excellent Sceadwian Excellent Sceadwian Excellent Sceadwian Excellent Sceadwian Excellent Sceadwian Excellent
    Join Date
    Oct 2006
    Location
    Rochester, NY U.S.
    Posts
    9,823
    Blog Entries
    1
    Latching push button momentary. Old AT power supplies used them as power switch for mains voltage so if you can find an old AT power supply it'll have one attached. I have a few in my parts bin. You can buy them from a site Digikey.com for spare change.
    straight answer, har har."
  3. #3
    twist2b Newbie
    Join Date
    Oct 2008
    Posts
    30
    Quote Originally Posted by Sceadwian View Post
    No, I have built many latching switches... thats not hard....
    I just want to have a TOUCH controlled switch.
  4. #4
    ccurtis Okay
    Join Date
    Dec 2008
    Location
    New Jersey
    Posts
    461
    The touch circuit looks solid enough, for a touch switch. Did you build it yet? Should take a matter of minutes to build.
  5. #5
    Join Date
    Oct 2006
    Location
    Rochester, NY U.S.
    Posts
    9,823
    Blog Entries
    1
    twistb last time I checked a button was a 'touch' I didn't take a look at your touch sensor circuit you need to be a little more specific =) If you want to latch the button output you can feed the input into a flip flop. That touch sensors is going to rely on slightly moist fingers and won't work with gloves or any non conductive touch. Very dry skin might not trigger it.
  6. #6
    Join Date
    Mar 2004
    Location
    Canada, of course!
    Posts
    19,820
    I think that static electricity from a finger will destroy the first inverter that has no protection.
    The circuit will not work if a person has very dry skin or is wearing gloves.
  7. #7
    Join Date
    Oct 2006
    Location
    Rochester, NY U.S.
    Posts
    9,823
    Blog Entries
    1
    Is that what the 1n cap to ground is for is static protection?
+ Reply to Thread
  1. Touch Sensitive Switch (Take 2)
    By MonkeyMera in forum Electronic Projects Design/Ideas/Reviews
    Latest: 15th February 2010, 09:38 AM
  2. Touch Switch
    By prprog in forum General Electronics Chat
    Latest: 23rd February 2009, 07:24 PM
  3. Touch switch
    By Asjad in forum General Electronics Chat
    Latest: 26th August 2004, 06:25 AM
  4. On/Off Touch Switch
    By ScarEye in forum Electronic Projects Design/Ideas/Reviews
    Latest: 24th July 2003, 07:12 AM
  5. touch switch
    By Josh in forum General Electronics Chat
    Latest: 3rd May 2003, 04:54 AM
Tags for this Thread
