Old 15th June 2004, 10:38 PM   (permalink)
Exo
A string is an array of bytes wich contains text, it's not meant to hold hex data...
what you need is a 2 dimensional array like this
Dim HexData(20, 5) as integer
this would make space for 20 characters data, 5values per charachter
then you load your data into it
HexData(1, 1) = &HC1
HexData(1, 2) = &HB7
HexData(1, 3) = &H77
and so on
now if you need to send a certain character, let's say character number stored in variable CharToSend you do it like this
for Loop = 1 to 5 do
Output = HexData(CharToSend, Loop)
Next Loop
where Output should be replaced with whatever means of output you are using...
Exo is offline   Reply With Quote
Old 16th June 2004, 04:05 PM   (permalink)
cwt
Wow~!!! :shock:
If initialise like that, the command will be very very long. Anyway, i get what you mean. I'll try that out.
Thanks~!! :wink:
I already give my best, i have no regret at all.
cwt is offline   Reply With Quote
Old 23rd June 2004, 06:40 AM   (permalink)
cwt
Hi..
Currently i am at the stage of shifting serial bits into parallel bits. I am using an UART PC16550D to do the shifting. I have a few doubts.
Besides taking care of the serial input pin and parallel output pins, what other pins should i included? :?:
Here is a diagram of the chip.
http://www.beyondlogic.org/serial/serial.htm#8
Thanks! :lol:
