hi friends, i have to use a hybrid stepper motor(1.8deg resolution) and interface it with 8051.I want to know why and exactly when is a stepper motor controller required.will i require it?and if yes how to decide which one..where can i find help regarding such stepper motor controllers...is L297-L298 appropriate? | |
You can either use an external controller (with integral motor coil drivers) to switch the coils, or you can just use Power Fets to buffer the Port pins on your MCU to drive the coils more directly, in which case you will have to implement the appropriate phase sequences and possibly phase overlaps ( µstepping) in your code that toggles the port pins. I have done this using the Parallel Port and some external big NMOS transistors on an old DOS computer | |
please guide me regarding how to select a stepper motor controller.....and will it reduce the programming?
| http://www.allegromicro.com/en/Produ.../3977/3977.pdf WILL reduce programming. check out their whole line if you do not like SMT. I usually reccommend that one since it is step and direction control, microstepping, drive FETS, and synchronous rectification all in one. Dan | |
| motor, query, stepper |
| How to use Stepper Motor as Normal Motor? | Irshad.mahamood | Electronic Projects Design/Ideas/Reviews | 8 | 22nd July 2009 01:18 PM |
| Stepper Motor IC | InPhase277 | Electronic Projects Design/Ideas/Reviews | 1 | 28th January 2009 12:04 PM |
| stepper motor or Torque motor | yagtoby | Electronic Projects Design/Ideas/Reviews | 1 | 14th June 2008 05:29 PM |
| Stepper Motor Vs DC Motor for wheels | AceOfHearts | Robotics Chat | 5 | 25th May 2008 04:16 PM |
| Stepper Motor Query | baberjaved | Micro Controllers | 3 | 24th November 2007 01:58 PM |
