+ Reply to Thread
Page 1 of 2
1 2 Last
Results 1 to 15 of 16
Thread: ADC0808/sensor reading error?!!
  1. #1
    Thirdium Newbie
    Join Date
    Jan 2009
    Posts
    16
    Default ADC0808/sensor reading error?!!
    Hello all,
    I've designed a crkt, to read sensor values, long story short, i have a rabbit MC, a bunch of sensors and ADC0808.
    Used also opamp to amplify some senor outputs, the problem is this:
    when i connect GROUND(0) to any input of the ADC0808 i get an output reading of 0.67 Volts! (Vcc=5, GND=0, Ref+= 5V, Ref- = GND).
    the other weird thing is that alll the outputs for the temp and other sensors are exactly the same as input(no 0.67v shift), yet only for the Pressure sensor i get a 0.67V shift...if i measure the input using a voltmeter i get 3.9v, but the output reading of the adc is 4.5V!!), note also that all components are connected to the same Ground rail, so no difference in ground).
    The pressure sensor i am using is "MPX4250A".
    i'd appreciate any help...thanks!
  2. #2
    Thirdium Newbie
    Join Date
    Jan 2009
    Posts
    16
    anybody ?
  3. #3
    Sceadwian Excellent Sceadwian Excellent Sceadwian Excellent Sceadwian Excellent Sceadwian Excellent Sceadwian Excellent Sceadwian Excellent
    Join Date
    Oct 2006
    Location
    Rochester, NY U.S.
    Posts
    9,823
    Blog Entries
    1
    Not a clue sorry.
    straight answer, har har."
  4. #4
    Thirdium Newbie
    Join Date
    Jan 2009
    Posts
    16
    c'mon guys! somebody out there can help me! its my graduation project, this is really gettin on my nerves, i have to start designing the PCB phase
  5. #5
    Thirdium Newbie
    Join Date
    Jan 2009
    Posts
    16
    any suggestion is welcomed...... coz its confusing me.... is it possible that conenctin the Rabbit microcontroller directly to the ADC0808 is applyin some kind of load?
    thanks
  6. #6
    Join Date
    Oct 2006
    Location
    Rochester, NY U.S.
    Posts
    9,823
    Blog Entries
    1
    You're getting different readings on a meter and the ADC, maybe the ADC is bad? Is the output from the pressure transducer a steady voltage or pulses? Pulses will screw up an ADC's reading big time.
  7. #7
    Thirdium Newbie
    Join Date
    Jan 2009
    Posts
    16
    Quote Originally Posted by Sceadwian View Post
    the output from the Pressure is steady, aslo if the ADC is bad why all of the other readings are correct?.
    again the weird thing is that when i connect the ADC input to the ground i get 0.67V, but when connecting any other sensor with an output over 0.67v i get a correct reading (no dc shift), except for the pressure sensor i get a 0.67v shift:S! its crazy, i can solve it by hardware, but solvin the problem without knowin what exactly the problem is! is not quit engineerin, and it is an issue when i discuss the project :'(
  8. #8
    Join Date
    Oct 2006
    Location
    Rochester, NY U.S.
    Posts
    9,823
    Blog Entries
    1
    Can you post your schematic?
  9. #9
    Thirdium Newbie
    Join Date
    Jan 2009
    Posts
    16
    Drawing it right now xD
  10. #10
    ccurtis Okay
    Join Date
    Dec 2008
    Location
    New Jersey
    Posts
    461
    I looked at this too, and I am at a loss for an explaination. The only things that come to mind are power supply bypassing, power supply noise, ground loops, the usual suspects. But, your results are good when most sensors are connected. Are you sure that nothing else is changing when you remove sensors to ground the inputs? What do you get for an output code with a floating input? The data sheet speaks of a potential DC offset if the input has filtering capacitors and a high source resistance. That might account for the pressure sensor, but not for the offsets when the inputs are grounded.
  11. #11
    Thirdium Newbie
    Join Date
    Jan 2009
    Posts
    16
    Thanks for the reply, well there are 2 notes to take in consideration:-
    1. For testing issues (before desiging a pcb) the rabbit is on the development board, meaning the voltage supply is takin from that board, and the supply for all other components(adc,sensors,opamps.etc) on a bret board is takin from an external battery(+9v and +5v regulator), but there is no difference in grounds(voltmeter measuring).
    2. Also there is a capacitor connected between the Pressure sensor output and ground ( 470 pF), i remember that i tried to remove it and nothing changed .
    i'll post the schematic once im done, hope it'll help!
    Thanks alot.
  12. #12
    Thirdium Newbie
    Join Date
    Jan 2009
    Posts
    16
    here is the schematic...well most of it, didnt include the microcontroller, signals are connected directly to the ADC, (ADD A,ADD B, ADD C, ALE, D1-D8, Start, EOC). Output Enable (OE) is connected directly to +5 v.
  13. #13
    Join Date
    Oct 2006
    Location
    Rochester, NY U.S.
    Posts
    9,823
    Blog Entries
    1
    You might want to put a decoupling cap on the VREF+ line to ground right next to the chip, a small electrolytic. I don't see anything blatantly wrong there (at least at the ADC) so I'm clueless =)
  14. #14
    Thirdium Newbie
    Join Date
    Jan 2009
    Posts
    16
    i told u it is drivin me crazy :P, anyways since my Vref+ is connected to the +5v rail, u can see that there is a ceramic capacitor 01uF connected between +5v and gnd.
    thanks
  15. #15
    Join Date
    Oct 2006
    Location
    Rochester, NY U.S.
    Posts
    9,823
    Blog Entries
    1
    Doesn't matter Thir. The VREF should have it's own bypass cap right at the chip, it's not in the data sheet for your chip but it's common practice with ADC's.
+ Reply to Thread
Page 1 of 2
1 2 Last
  1. interfacing ADC0808 with lm 35 temp sensor
    By salim nadaf in forum Electronic Projects Design/Ideas/Reviews
    Latest: 20th October 2009, 12:14 PM
  2. Remote sensor reading from desktop ...
    By john1 in forum Electronic Projects Design/Ideas/Reviews
    Latest: 2nd September 2008, 01:27 PM
  3. RF for sensor reading and valve actuation
    By NJ Roadmap in forum General Electronics Chat
    Latest: 3rd February 2007, 03:01 PM
  4. 2051 reading car coolant temp sensor?
    By SPD010273 in forum Micro Controllers
    Latest: 24th May 2006, 08:04 PM
  5. PIC code Error checking help (DS1820 temp sensor)
    By NewGeek in forum Micro Controllers
    Latest: 10th September 2004, 07:42 PM
Tags for this Thread
