+ Reply to Thread
Results 1 to 3 of 3
Thread: Wanted Adjustable ACV Circuit
  1. #1
    elektrodude Newbie
    Join Date
    Mar 2009
    Posts
    2
    Default Wanted Adjustable ACV Circuit
    Hi Dear All
    Im new comer here ,I want to make a circuit that can adjust stepped down 12VAC(0-12v) like DC circuit by using LM317..I dont want to use variac or transformer secondary taping points with rotary switch..Plz note I'm using step down transformer for getting 12vac from main with 1 or 0.5Amp current..
    Thanking you All in Anticipation...
  2. #2
    colin55 Bad colin55 Bad
    Join Date
    Feb 2009
    Location
    Melbourne Australia
    Posts
    1,501
    LM317 only works on DC.
    One way to get the AC voltage you want is to add a wire wound resistor. The voltage you get will not be accurate and it will vary according to the current you draw.
    But, for instance, if you are drawing 1amp, put a 3R3 5watt wire wound resistor in one line and measure the voltage.
    If it is too low, put a 10R across the 3R3.
    Alternatively you can put a wire wound pot (called a rheostat) in one line and adjust the voltage. (These are expensive and you will need a 10 watt version.)
    The other method is to put a number of 1 ohm wire wound resistors (5watt each) in series and use a clip to tap off the voltage you need.
  3. #3
    tcmtech Excellent tcmtech Excellent tcmtech Excellent tcmtech Excellent tcmtech Excellent tcmtech Excellent tcmtech Excellent tcmtech Excellent tcmtech Excellent
    Join Date
    Feb 2009
    Location
    Sawyer, North Dakota, USA
    Posts
    3,285
    Blog Entries
    2
    Back to back LM317's! One does one half of the wave the other does the reverse half.
    Dont forget the blocking diodes and reverse diodes!
+ Reply to Thread
  1. Piezoelectric Transducer Driver Circuit With Adjustable Output Level
    By romosco in forum Electronic Projects Design/Ideas/Reviews
    Latest: 17th May 2009, 07:55 PM
  2. Want Adjustable AC Voltage Circuit
    By elektrodude in forum Electronic Projects Design/Ideas/Reviews
    Latest: 23rd March 2009, 05:07 PM
  3. Adjustable on and off circuit help...
    By BRS in forum Electronic Projects Design/Ideas/Reviews
    Latest: 6th January 2008, 04:29 PM
  4. Circuit diagram for an adjustable current regulator
    By Futterama in forum Electronic Projects Design/Ideas/Reviews
    Latest: 11th January 2006, 12:59 PM
  5. circuit help wanted
    By mstechca in forum Electronic Projects Design/Ideas/Reviews
    Latest: 28th June 2005, 06:55 PM
Tags for this Thread
