+ Reply to Thread
Page 2 of 2
First 1 2
Results 16 to 20 of 20
Thread: Alternator simulator circuit
  1. #16
    kchriste Excellent kchriste Excellent kchriste Excellent kchriste Excellent kchriste Excellent kchriste Excellent kchriste Excellent kchriste Excellent kchriste Excellent
    Join Date
    Jul 2006
    Location
    Victoria BC, Canada
    Posts
    3,681
    If you had 400Hz 3Φ in your shop it would be easy.
  2. #17
    tcmtech Excellent tcmtech Excellent tcmtech Excellent tcmtech Excellent tcmtech Excellent tcmtech Excellent tcmtech Excellent tcmtech Excellent tcmtech Excellent
    Join Date
    Feb 2009
    Location
    Sawyer, North Dakota, USA
    Posts
    3,263
    Blog Entries
    2
    I still say filter the alternator. Kill the noise at its source. why prune each leaf of a weed every time it grows a new one? Kill the root at its source. Still just a thought.
    If the system is a 30 amp. the capacitor values could only need to be a few 1000 uf and possibly not need a filter choke.
    True lazyness is the real motivator to do it right the first time!
    Doing it wrong, then doing it over is just misguided ambition!
  3. #18
    MikeMl Excellent MikeMl Excellent MikeMl Excellent MikeMl Excellent MikeMl Excellent MikeMl Excellent MikeMl Excellent
    Join Date
    Mar 2009
    Location
    Utah
    Posts
    2,853
    Quote Originally Posted by tcmtech View Post
    I still say filter the alternator. Kill the noise at its source...
    I have tried "filtering" an alternator with just a large 47,000uF "computer grade" electrolytic capacitor, and it does NOT work. The effective series resistance of a large electrolytic capacitor is more than 10mOhms at 120Hz. I suspect that the ESR is much higher at kHz frequencies. The impedance being bypassed (30A loads, the battery) is much less than 10mOhms, so most of the ripple current still flows along the airframe to the loads and battery.
    It would require putting a series choke of more than 100uH (that will not saturate at the max alternator current of 60A) between the alternator and the loads and battery.
    Electrically that might help, but practically, it would never fly. It raises all kinds of FAA certification issues due to modifying an existing design, and introduces several failure modes. Those large electrolytics hate elevated temperatures (engine compartment is over 130degF), and they hate vibration. Fusing the path to the electrolytic wont work because the resistance of the fuse is a few hundred mOhms, which kills its effectiveness as a bypass for the ripple currents.
  4. #19
    Join Date
    Feb 2009
    Location
    Posts
    3,263
    Blog Entries
    2
    Ah. computer caps do have rather poor high frequency response.
    Good point on the FAA regs though.
    Chase the ground loops it is!
    sure its just alternator? No feed back from the duel ignition circuits?
  5. #20
    crutschow Excellent crutschow Excellent crutschow Excellent crutschow Excellent crutschow Excellent crutschow Excellent
    Join Date
    Mar 2008
    Location
    USA
    Posts
    3,009
    Quote Originally Posted by Sceadwian View Post
    I guess it would be down to which is harder. Removing the prop without disconnecting said pitch control hydraulics and loading the main output shaft to allow the engine to run, or disconnecting the drive belt to the alternator and putting in an electric motor to drive it. It's starting to sound like simply electrically disconnecting the alternator and putting in some kind of direct electric simulation would be smarter, if not easier. Honestly, I'd just come up with a practical way of working around the aircraft while running, even if you need a separate person for safety alone it sounds more practical than most methods so far, unless you plan on doing this repeatedly.
    The intention of my suggestion (which apparently was not clear) was to use a separate external alternator and motor, not to drive the alternator in the aircraft.
    It probably isn't necessary to disconnect the aircraft alternator when you connect up the external unit since the alternator is already looking at the battery voltage anyway.
    Carl
    Curmudgeon Elektroniker
+ Reply to Thread
Page 2 of 2
First 1 2
  1. Circuit simulator for micrcontroller....
    By HiteshDR in forum Datasheet/Parts Requests
    Latest: 4th December 2007, 06:51 AM
  2. circuit simulator
    By mayankguru in forum Electronic Projects Design/Ideas/Reviews
    Latest: 9th October 2007, 01:34 PM
  3. Argh! Circuit Simulator?
    By Marks256 in forum General Electronics Chat
    Latest: 10th December 2006, 09:55 AM
  4. Circuit simulator
    By akg in forum General Electronics Chat
    Latest: 29th November 2005, 01:07 PM
  5. another circuit simulator question
    By jrz126 in forum General Electronics Chat
    Latest: 6th January 2005, 09:37 PM
Tags for this Thread
