I'm planning to build a regulated linear power supply like the one in this link:
Power Supply
(I may add another capacitor for the adj. line, as well as protection diodes).
However, I want to know if one major modification is feasible!
I will be using a 24v center-tapped transformer, ignoring the center tap when I need to provide 15-30V. What I want to know is if I can simply place a switch to select either the center tap or the full tap, thus being able to have a HIGH and LOW voltage mode to minimize the power dissipation over the LM338 when powering a load below 15V (and also make 5V @ 5A possible).
Will the resistor values intended to vary the output up to 30V be an issue?
And if this all is feasible, is there a simple way to have two LEDs indicating whether the supply is operating in HI or LO?
